Commit clip is too hot!! Help!
I want to commit a clip to a new track as it's original volume and now it turns out like a hot, compressed waveform!
I've tried just about everything I could think of: - Made sure volume levels were all '0' - Checked and unchecked all the automated reneder choices in the boxes in the 'Commit Track' box - Made sure there were no effects on any insert boxes to get applied to the committed track - Help! |
Re: Commit clip is too hot!! Help!
Anyone?
Check the output volume of the VI, if 0 is too hot try -6 or -12 or -whateverworks
Good luck
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
I was PM'ing amagras and mentioned that how I make a finished track is that I make a mixdown, then trip that waveform, then commit it to it's finished track.
It's like it's being compressed and I still can't figure it out how to get it to commit and look like the original waveform. To my knowledge I'm not using and VI's. |
What happens if you set the auto mode to read instead of off on the track PRINT?
Try freezing the original track and see if that then looks clipped also. Hopefully I've explained this clearly enough, sorry if I haven't. Does it sound like a clipped version of the original?
Mac Studio M1 Ultra 64GB macOS 13.2.1 Pro Tools 2023.3 Antelope Audio Discrete 8 SC Last edited by DarkandKurious; 11-30-2016 at 02:07 AM. Reason: more thoughts |
Dark - that is very interesting. I don't know much about the terminology of "32bit floating point". Last edited by firmflange; 11-30-2016 at 04:20 PM. |
My mistake, the volume and mute options helped.
So when you committed with the volume automation in read, and had the volume ticked as a commit option, the track committed okay?
On the original bounce, if you set the metering to pre-fader, do you see yellow clip lights on the track? If the metering is set post-fader, do you see clip lights on the track?
Mac Studio M1 Ultra 64GB macOS 13.2.1 Pro Tools 2023.3 Antelope Audio Discrete 8 SC |
x form rendering blank files when choosing clip by clip audiosuite | dj_grimmace | AAX Plug-ins | 2 | 06-21-2017 11:29 AM |
x form rendering blank files when choosing clip by clip audiosuite | dj_grimmace | Pro Tools 11 | 1 | 03-04-2017 12:35 PM |
Issue dropping more than one clip into the Edit Window with Clip Transparency ON | arb232 | Pro Tools 12 | 0 | 02-10-2016 06:01 PM |
Strange Clip LED Behavior. No Clip LEDs on PlugIns anymore ? | innenhofstudios | macOS | 14 | 08-19-2013 10:29 AM |
To Commit or not to Commit, that is the question. | georgejw22 | Pro Tools 10 | 10 | 12-20-2011 05:30 AM |
