Old 09-13-2016, 10:52 AM
holler holler is offline
Default Re: PT12.5 & Vocalign Project
Yeah, like someone mentioned make sure the clips are the same length, I usually select the shortest one and go down and separate the others from that one! Low flexibility can be something to try as well!
Old 09-13-2016, 11:50 AM
midnightrambler midnightrambler is offline
Originally Posted by JFreak View Post
Vocalign is much faster if you have lots to align. That's why. And if you slice your stuff to shorter clips it isn't that bad. Every now and then you need to re-render, but still much faster than doing it in Melodyne. At the end of the process you just consolidate and scrap the million small unnecessary clips.
Sure it's fast. And I always found it ok-ish if you're only using it for stacking. Always found it slightly embarrassing if I had to send off vocal stems or acapellas that had been processed with it though, with all that gurgling and whatnot. YMMV.
Old 09-14-2016, 12:10 AM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Works well in 12.4. I've used it since PT8.
In 11 and later make sure you're hitting Align before Spot.
Always use the same selection length.
Vocalign Project LE guitardom Buy & Sell 2 08-19-2013 09:10 AM
VocAlign Project vs. VocAlign Pro apoc64 Post - Surround - Video 3 02-27-2012 11:53 AM
VocALign Project 2.97 LE? rainsong macOS 4 01-28-2012 05:03 AM
VocALign Pro Or VocALign Project? Mark 66 Post - Surround - Video 3 09-18-2006 10:05 AM
VocALign Project mman00 Pro Tools TDM Systems (Mac) 0 01-10-2002 09:29 AM
