Old 05-16-2017, 04:09 PM
john1192 john1192 is offline
Default Re: Low latency monitoring, no sound in PT12,help?!
Originally Posted by Carl Kolchak View Post
I haven't had to deal with this in a while, so I'm probably remembering this incorrectly, but :
In the olden days, Low Latency Monitoring mode had to be selected from one of the top menus (Set-up, possibly???), and only worked on audio tracks that were routed directly to hardware outputs 1 & 2. All plug-ins on these record enabled tracks would automatically become bypassed.
LE devices, such as the 002 / 002r had a built in DSP mixer that would facilitate this low latency mix.
At some later point in time Low Latency Monitoring completely changed it's functionality - the term remained the same, but it no longer utilised the DSP mixer to handle low latency mixes.
Instead (and now activated by right clicking in the sample display below the mixer channels) it acts as "Input Muting", to be used in conjunction with modern 3rd party audio interfaces (such as a UA Apollo, or Avid's own Mbox 3 that has it's own DSP mixer, and dedicated mixer application), or conventional mixing desk, to allow direct monitoring, without the inconvenience and echo of double monitoring.
hey Karl, been the same behavior since PT10.3.10.613 (the final release) ..
i found this .. i use 3rd party interface .. i never expected it, so never use it ..
http://avid.force.com/pkb/articles/e...049&popup=true
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 09-10-2017, 05:00 PM
nate9's Avatar
nate9 nate9 is offline
keep turning the volume up on the mic pre and tap the mic, you might have to tap the mic hard, until you hear the sound coming through
Control24, Digi 002, Rosetta 800, KRK V8's, PT 7.4
Macintosh G5 Dual 2.0 3 gbs ram
Old 09-12-2017, 10:59 AM
nate9's Avatar
Default Low latency monitoring, no sound in PT12,help?!
I had to the mess with auto/input monitoring only and place a little, might been the record button too, but I got it to work!
Low Latency Monitoring - No Sound Vervus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-27-2010 01:13 PM
Low Latency Monitoring on - no input sound amayhem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-26-2010 12:10 PM
no sound with low latency monitoring hubbellclef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-19-2007 02:51 PM
Low Latency Monitoring -- No Sound Sheep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 04-12-2003 04:50 AM
Low Latency Monitoring -- No Sound Sheep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-02-2003 06:48 AM
