Pro Tools 2018.7 Hangs at start - W10
Hello,
First, I can use PT and it works pretty well on my system except the following problem ! I recently tried to make a PT Template with ALL my Orchestral Sound Banks. I essentially use Native Instruments Kontakt 5.8.1. I loaded 18 instances of Kontakt in different intruments tracks to fit my needs, then loaded my sounds, created the desired aux outputs, created all my midi tracks, etc... I also use Omnisphere 2.5, Keyscape, Native Instruments Maschine and the UVI Player, also loaded in my session. All seemed to go well, i closed my session then re-opened it and Pro Tools hanged, i tried several times to reload my session after restarting my computer but for now it hangs in the edit window just after loading. No errors, no unexpected quits, it just hangs… It just happens on that session, on other smaller smaller project sessions, everything is fine. My specs: Intel 3700 Gygabyte Z77-D3H 32 Go RAM DDR-3 2600 4 SSD Drives Samsung 840 EVO - 1.5 T UAD Appollo Twin Duo Usb3 Renesas PCIe USB3 Extension Windows 10 Professional V.1803 No Anti-virus Avid Application Manager, Mac Drive and Google Drive as main background tasks. If anybody have an idea… I use Cubase also but I would like to use Pro Tools as it has some features i miss a lot when i work on Cubase… Thanks, Meaks. |
Re: Pro Tools 2018.7 Hangs at start - W10
Nobody here can guess... you need to troubleshoot this. Trash prefs, check plugins are up to date, try importing into a new session, try recreating by hand in stages and testing by restarting at each stage, and so on...
Thank you for your quick response.
I'll look into it more deeply, but, while trying to unload some Sound Banks by Moving them from their original folder, the session actually loaded without the "8dio Passionate Piano". So far so good… Anyway, thanks. Meaks. |
You could also start a new blank session, import the data from your template session and then create a new template from your new session and see if that works...
http://www.PhatMonkey.me Windows 10 64bit | Asus Rog Hero Xi | Intel i9-9900K | Corsair LPX Vengeance 64g DDR4 RAM | Avid Mbox Pro 3 | Focusrite 18i20 2nd Gen | MSI RTX 2080TI Gaming X Trio | Acer Z35 Predator Monitor |
Or try this:
Hold the SHIFT key while you open your session. This will make all plugins inactive(all settings remain). Assuming that allows the session to open, I would enable maybe the first 6 out of your 18 total VI plugins and save the template that way(I suspect the rig is choking on trying to open 18 instances at once, so give it less work to open). You can activate more plugins as you need them. My template session has tons of plugins in place, but many(in my case, its all with high latency) are inactive to start. I activate as the need calls for. Hope this helps
Pro Tools 2018.1.0 start time | critza | Pro Tools 2018 | 8 | 11-02-2018 10:14 AM |
Pro Tools 2018.1 won't start | R.Rhoads | macOS | 2 | 03-16-2018 12:46 PM |
Help! Protools Start Up Hangs on start up | stefankruger | macOS | 2 | 06-10-2013 02:10 PM |
PT Hangs on start up | Dave Labrecque | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-27-2010 12:49 PM |
MDD - Hangs on Start Up | orcado | Tips & Tricks | 7 | 02-07-2010 01:27 PM |
