  #81
Old 10-02-2018, 04:40 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Re: 10.13.6 with 2018.7 ... best version ever!? Holy Sssh
Originally Posted by Sergius View Post
How would you tell/know about the "supplementary 2" update?
I updated recently around 9/19, and it literally feels like I have a new computer.
This is the best combo (10.13.6+PT 2018.7.0) in a while.
Through App Store, sends a notification of waiting to be installed updates for my MBP.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
  #82
Old 11-08-2018, 07:21 AM
Persyst Persyst is offline
Hi Mattian,
Could you possibly verify whether or not you are able to export an AAF file running PT 2018.7 on OS 10.13.6?
I have PT 2018.10 installed on OS 10.13.6 and PT just gets stuck when trying to export an AAF file. Previously I was running PT 12.5.1 on OS 10.13.6 and I had the same problem. My post link regarding this problem for reference http://duc.avid.com/showthread.php?p...43#post2505043
These are the settings I used
And this is the screen where PT just gets stuck after I hit OK on the previous image
If you could verify this problem for me that would be GREAT!!!
Thanks!!
System Details
Media Composer 2020.6
Pro Tools 2019.6
Mac Pro 2013, MacOS Mojave 10.14.6
• 2.7GHz 12-core with 30MB of L3 cache
• 64GB (4x16GB) of 1866MHz DDR3 ECC
• 1TB PCIe-based flash storage
• Dual AMD FirePro D700 GPUs with 6GB of GDDR5 VRAM
  #83
Old 11-08-2018, 07:59 PM
smurfyou smurfyou is offline
Originally Posted by Persyst View Post
Hi Mattian,
Hi, I just tried this on 2018.7 under 10.13.6 and it worked. It did beach ball 3 times for about 20-30 seconds each which was weird. This was a stereo track with about 18 clips so nothing big.
~Will
  #84
Old 11-10-2018, 10:50 AM
tclash tclash is offline
Just chiming in with my experience. I had some downtime and was going to try Mojave on my 2009 Mac Pro (with 6-core @ 3.46ghz, 16GB RAM), but wasn't aware of the GPU requirements. So... instead I installed 10.13.6 w/PT 2018.10. So far it has been running great. I can play back moderately heavy sessions (80+ track full mixes) with no problems, 25-30% CPU usage, even at 32 buffer. If I put a track into record it will spike at 32 & 64, but no problems recording at 128. I do 99.9% mixing so I'm not seeing this as a big issue. But hopefully someday before we all die there will be an officially approved version for 10.13.6.
  #85
Old 11-10-2018, 11:10 AM
Sugarnutz Sugarnutz is offline
I'm on a 15" mid 2015 rMBP/16 Gb/512 Gb Flash Drive. I started out with Sierra, but before I set up my DAW stuff I upgraded to High Sierra 10.13.6. I'v never had an issue with PT or Cubase, but I never did a lot on this MacBook Pro until PT 2018.7 came out, Cubase version is 9.5.41.
Yesterday I decided to compact my system as I had High Sierra on a USB 3.0 external 128 Gb SSD for mail, web, etc.... I resized the 512 Gb flash partition (or container) to 300 Gb and added a container with the balance for a Mail & Web setup, but I installed 10.14.1 Mojave on this container. The only issue I had with Mojave was 4 1/2 hours downloading it from Apple's 22 Mb installer. After Mojave was up and running I could download the full 6 Gb intaller in less than 30 minutes. Go figure!
So far with Mojave I've installed Office 365, Chrome, iHeart Radio from the app store with no issues. I have a Behringer UMC404HD I use for remote sound effect recording (Don't laugh, my main interface is a Antelope Audio Zen Studio+) which Mojave connected right up and is working well, nothing serious yet though, no PT or Cubase.
Over time I'll try more with Mojave, but for now I'm sticking with 10.13.6 for audio work.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
  #86
Old 11-14-2018, 07:13 AM
ejsongs ejsongs is offline
how is 10.13.6 working with hdx?
ej
  #87
Old 11-16-2018, 03:23 PM
sjallyn sjallyn is offline
Unfortunately with newer hardware (i9 processor) and 10.13.6 which is all that unit can run (except Mojave) PT fails miserably for recording. If I record more than about 15 minutes straight, no plug ins, only a few tracks I get a CPU overload and it stops recording. This makes "Live" recordings completely unworkable with this combination. And PT is the ONLY DAW with this problem on the very same hardware, Tracks Live, Audition, Audacity, Logic Pro, Reaper and others all work fine, only PR seems to have this problem. 10.11.4 is over a year old, the i9 machines came out in June. I've been with PT since the beginning but I am really thinking about cancelling my subscription if I cannot use it anymore. I understand about Mohave, but I don't understand about 10.13.6. Of the 50 pieces of software in my company PT is the ONLY one not running on this OS.
  #88
Old 11-26-2018, 11:06 AM
xrekcor's Avatar
I must admit the upgrade to 2018.10 seems to have brought this issue back again somewhat for me.
Rob
  #89
Old 12-25-2019, 07:34 PM
drago76 drago76 is offline
Hi everyone, I’m planning to go from tdm 10.3.8 to hdx and I would like to know wich version is more stable with less errors!
Do you still think that version 2018.7 is the best or there’s some new release that’s even better?
I will use it on High Sierra!
Luke
  #90
Old 12-25-2019, 09:04 PM
BScout BScout is offline
2019.6 with 10.13.6 (High Sierra)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Is Pro Tools 2018 EVER going to be supported on a current Version of High Sierra? off the wall macOS 10 01-05-2019 04:53 PM
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues Dudiester Pro Tools 2018 5 08-12-2018 08:33 AM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Permission Denied (13) on Launch -Pro Tools 12, Version 2018.1 Randroo Pro Tools 2018 7 05-07-2018 08:11 AM
Does the 2018 boxed version come with iLok 2 or 3 and ... rique000 Pro Tools 2018 3 02-23-2018 06:11 PM
