RME ASIO 1024 sample buffer - possible w/PT9?
Hi all
I'm running PT 9.0.6 under Windows 7 and currently using an RME Babyface with driver 1.019. Previously I was using an RME Fireface 400 (with whatever the most recent Fireface driver is). In both cases, if I launch PT9 with the RME ASIO buffer set to 1024 samples, PT simply doesn't play (with ANY session). No error message, but no audio either. It is as if transport has not even been clicked. Changing to a buffer size smaller than 1024 works fine. Is this a known issue? It seems odd that the larger buffer would be a problem but the smaller buffer is not.
Sound design, audio editing, and instrument programming for Kontakt and MachFive http://www.iainmorland.net |
002R ASIO stuck at 1024 buffer problem | zolko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-28-2014 02:52 AM |
So what's with the 1024 sample bounce bug? | dougied | macOS | 1 | 11-30-2011 06:54 AM |
Buffer Engine now only goes up to 1024? | anackman | macOS | 7 | 10-01-2011 12:50 PM |
1024 buffer max, used to be 2048 in PT8 | Sturphy | Pro Tools 9 | 8 | 12-02-2010 07:53 AM |
1024 buffer vs. 2048 ?? | SoundtrackArcade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-02-2007 01:28 PM |
