Pro Tool Edit Window/Posting Thread question
I have a couple problems. One with PT itself and the other is with this forum.
First, when I start PT the load screen shows full and the Edit toolbar is fully visible. When it finishes loading however, it shrinks to a 3/4 size and the Edit toolbar is cut in half. Second, how do I post a new thread on here? I have spent WAY too much time trying to figure this out.
"Never underestimate the power of stupid people in large numbers" |
Re: Pro Tool Edit Window/Posting Thread question
I've moved your post to its own thread.
If you're opening a saved session, the Edit and Mix windows should be where you left them. I'm not at my DAW right now to look into the default window layout to verify, but this old article might help:https://www.soundonsound.com/techniq...configurations To create a new thread, select the appropriate section, then there will be a "New thread" button at the top left. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Multi-Tool in Edit Window cursor frustration | Brian Hudson | Pro Tools 12 | 20 | 03-31-2020 10:23 AM |
Locked - Cannot use selection tool anywhere in edit window or move clips! | eneedham | macOS | 30 | 05-05-2012 08:23 PM |
Help with posting a link in a thread | David Penick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-05-2006 10:40 AM |
Edit To Mix Window Makes Pro Tool Freeze | erna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-20-2003 01:38 PM |
Question for Edit/Pencil-Tool in PT-LE 6.1 (PC) | loitschix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-13-2003 06:33 AM |
