Old 05-13-2002, 10:37 PM
Neveguy Neveguy is offline
Default Best bounce
I have recently been told by the guys that master most of the stuff I do that they want the finished mixes as 24bit 48k interleaved files.
I mix into Protools via outboard so I have 2 mono 24bit 48k files.
The question is do I bounce to disk to convert to interleaved or is using shift-apple-k (export selected) the same deal?
The former takes real time and then some while the latter is quite speedy - another worry I guess - slower is usually better.
Any ideas?
Old 05-14-2002, 06:59 AM
SoundWrangler SoundWrangler is offline
Default Re: Best bounce
Export command from Audio Regions List exports/combines .L/.R file pairs "as is". File menu's Bounce command is real-time (as you know), & also incorporates any level adj, routing, plug-ins, etc. in your Session. If your mission is to combine them "as is" - all unity gain, no routing/processing, result should be exactly the same either way, so the File menu's real-time Bounce offers no benefit & takes longer. BTW, the Bias Peak prog. can also automatically combine .L/.R files as they're opened.
Bounce to Disk issues and bounce to direct show error. SeattleHank Windows 7 01-01-2014 01:41 PM
Elastic Properties Stuck? --pre bounce vs. post bounce alithomas66 Pro Tools 9 2 02-07-2012 06:56 PM
Bounce to disk error - pro tools won't let me bounce the file! HipHopHead Pro Tools M-Powered (Win) 1 05-14-2009 12:13 PM
Bounce To Disk inserts silence at start of bounce - PT 6.4.1 innerbooty Pro Tools TDM Systems (Mac) 1 04-18-2007 09:13 AM
5.1 wont bounce. Says "bounce handler cant keep up try convert after bounce...." Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-21-2001 09:28 PM
