Old 05-10-2002, 10:36 AM
ianmiller ianmiller is offline
Default Solo automation
Hi there - I have a song where I want to solo three tracks for a few bars and then bring everything back in. I am trying to automate this - does automation work with the solo button? If not, how do I do this. I could mute everything and then un-mute but that seems very fiddly - thanks for any advice
Old 05-10-2002, 02:38 PM
Brent Hahn Brent Hahn is offline
Default Re: Solo automation
Try this (and trust The Force):
Save.
Set automation to All Touch.
With your markers ruler visible, put markers at the start and stop of the area you want to solo. You'll need this visual cue.
Turn automation off on the 3 appropriate tracks, and any effects returns associated with them.
Hold down the option key, hit play, and when you get to the first marker, mute one track. All tracks will mute, giving you dead silence. When you get to the second marker, unmute one track and they'll all unmute.
Reset automation to All Touch.
Brent Hahn
http://www.radioactive.la
Old 05-11-2002, 08:35 AM
Thanks - good tip and the force was with me! However, I had a few muted hidden tracks and it of course also brought those back to life scaring the bejazus out of me until I fugured out what was going on ! Thanks again
Old 05-11-2002, 09:49 AM
Actually -- and I can't believe I actually walk around obsessing about stuff like this -- I came up with another (non-automation) way that might be even slicker & quicker.
Place your 2 markers as in the previous exercise. At each marker, do a separation across all tracks (command-B). Select the area between the markers on all tracks except the ones you don't want to mute. Hit command-M to mute all these regions. Done.
Brent Hahn
Old 05-12-2002, 02:49 PM
Dr. J Dr. J is offline
We always cut the other tracks out, and smooth with fades if necessary, when editing. Also use compression on the amser to really brign those 3 tracks to the front.
jay@jayriggs.com
www.jayriggs.com
www.fifty-fiftymusic.com
Turn Me Up!™ – Sign Up Now to Bring Dynamics Back to Music (www.TurnMeUp.org)
Automation, mute, solo stops working. Svante Biörnstad Pro Tools TDM Systems (Win) 0 11-15-2007 03:12 AM
Solo Automation Arch Stanton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-31-2007 08:07 AM
Solo Automation? torquemada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-18-2006 05:31 PM
Solo with mix automation? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-20-2005 12:01 AM
solo automation sidereal Pro Tools TDM Systems (Mac) 0 11-21-2001 12:00 PM
