Old 05-06-2002, 08:00 PM
Straylight001 Straylight001 is offline
Default 24-bit converters and PTIII PCI
Some of the people I have talked to on here have said that PTIII PCI is 16-bit only. Why then, does it allow for connections to the 888/24, 882/20 and 24-bit ADAT interfaces? If it were 16-bit, wouldn't it just ignore the extra bits? I'm confused.
Old 05-07-2002, 10:47 AM
DigiTechSupt's Avatar
Default Re: 24-bit converters and PTIII PCI
Yes, Pro Tools III hardware is 16 bit hardware, it writes 16 bit audio files to disk. It will support 888/24, 882/20, etc. for compatibility reasons but is still limited to 16 bit sessions. When the 888/24 was released the 888/16 (actually it's an 18 bit device) was discontinued and PT III systems were still being sold.
However, if you go in and out of a PT III system digitally (with an 888/16, 888/24, etc), it will pass a 24 bit signal as long as you don't write to disk. In other words, you could use a PT III system as a 24 bit signal processor (reverbs, EQs, etc.)
Also, 888/24 interfaces sound better than the 888 regardless of what bit depth you use.
Jon Connolly
Digidesign Product Specialist
Avid Audio Tech Support
Support FAQ
Old 05-10-2002, 01:40 AM
dubgeist dubgeist is offline
also you can do 24bit mixes with PT3 hardware .... and it sounds better! still only 16 bit Disc tracks BUT add a few together and words start to get alot longer ..... long live PT3 ... i a'nt selling mine .....!
Old 05-10-2002, 02:17 AM
digidesigner digidesigner is offline
to dubgeist - how are you doing 24 bit mixes on PTIII?
Alesis AI-3 Converters VS Digi 002R Converters spicyitaliano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 01-19-2004 07:51 PM
001 converters and preamps vs. oo2r converters and 16yearsjeff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-07-2003 09:08 AM
Mbox converters Vs Digi002r converters theloy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-23-2003 01:00 AM
002 converters vs apogee mini me converters westgate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 34 01-20-2003 03:16 AM
Digi converters vs dbx 376 channel strip converters Bloux 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-02-2002 06:14 PM
