Old 07-04-2020, 07:43 AM
stefanboman stefanboman is offline
Default Soft keys screens Swapped around
After updating to 2020.6 my soft keys screens got swapped around.
It thought I’ve seen an option for swapping screens around between the top and bottom pairs but I can’t find that setting.
Is there an option for this that I’m missing?
Ps. My soft keys are edited with Eucon layouter if that makes any difference.
Stefan Boman
Atlantis Studios-Stockholm
www.parkstudios.se
stefan[at]atlantisstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 07-04-2020, 07:46 AM
creativecontrol's Avatar
Default Re: Soft keys screens Swapped around
Greetings,
If you’ve customized your own unique set you may simply have to re-load that XML file from Settings > SoftKeys > Load. As a test, you can hit default and it will revert to the factory shipped soft keys. Before you hit default make sure you have saved any current tweaks you’ve made.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-05-2020, 01:25 PM
Hi Jeff,
I did load that file but everything is on the wrong screens.
I have used this XML file on several S6 versions before without this issue.
My top two screens is now in my bottom two screens and vice versa.
Really strange!
Any ideas on how to sort this?
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 07-05-2020, 01:26 PM
Can you please share the XML and I will check it out? Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Soft Keys - System Soft Key Display Mode skilletaudio Avid S4/S6 0 09-25-2019 09:07 AM
Soft Keys walter rohrbach Avid S1, S3, Dock and Control App 2 05-11-2019 12:26 AM
How to Adress Function Keys >F12 from the S6 (Soft Keys) innenhofstudios Avid S4/S6 3 05-08-2019 06:34 AM
Soft Keys spoons Avid S1, S3, Dock and Control App 13 10-21-2016 07:37 AM
Why no Soft Keys on S3? jacko Avid S1, S3, Dock and Control App 15 02-09-2016 07:43 PM
