Old 05-28-2020, 10:03 AM
quadraphonics quadraphonics is offline
Default Pt 2020.5
All,
I have been testing PT Ultimate 2020.5, to see if it will work better than 2019.5 does for us.
For the most part I have found that it is ok, but there are a few behaviours that I would like to see if anyone else has run into.
1.) If a breakpoint is close to a clip edge, occasionally 2020.5 will ignore the automation, or otherwise playback improperly. Example: breakpoint automation is on a clip edge and is pulling the clip down 6dB. Occasionally, playback will ignore the breakpoint and playback the clip 6dB too hot.
2.) Playback seems to continue slightly after hitting stop. This seems to be consistent and happens whether I have post roll enabled or not. This is kind of annoying. I seem to remember this being an issue on an older version at one point and there being a not obvious solution to it.
Any help would be appreciated.
Thank you,
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 05-28-2020, 11:57 AM
friendlybunny friendlybunny is offline
Default Re: Pt 2020.5
I have been using 2020.5 for a bit. I haven't been able to replicate those issues.
I'm still on Mojave, so I'm not sure if that makes a difference.
For the playback continuing... The playback cursor seems to visually keep going after my out point, but the audio playback does stop at the correct out point. It is visual, but not audio on my end.
Old 06-02-2020, 01:00 PM
reichman's Avatar
reichman reichman is online now
I read your post a few days ago and thought 'whatever,' haven't seen it. Now I'm taking a break from a full mix pass and I'm seeing Pro Tools ignore the Auto Join in Latch mode, just like you saw. It hits a cliff edge volume change and the VCA kicks into latch and looks like it's writing the correct automation, but what's coming out of the speakers is totally wrong. Totally repeatable.
Do you have a support ticket in? Should I make one?
Not seeing your #2 issue.
PT 2020.5, macOS 10.14.6, Eucon 20.5, Mac Pro 6,1.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 06-03-2020, 01:57 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Does the automation issue also happen on 'regular' automation or only on a vca?
I drag down volume automation from clip edge to clip edge a LOT on background fx
Old 06-03-2020, 06:08 AM
reichman's Avatar
Good question about ‘regular automation.’ I don’t know, but Avid support requested that I send a video, which I did. And automation playback sounded right to me when I did my last pass last night. So maybe the issue is restricted to certain functions. I don’t use offline bounce, so I’ll just keep listening (as always).
Nathaniel Reichman
Dubway Studios
Old 06-03-2020, 06:33 AM
I see it happen with both.
Randall Smith
Audio Editor/Mixer
Denver, CO
Thanks for looking into this. I do not yet have a support ticket in. I will try to get one in this week.
Thanks,
Randall
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 06-29-2020, 01:53 AM
Farhoof's Avatar
I'm seeing this as well in PT 2019.6 now, send levels pulled up or down by an entire selection (so there are only breakpoints on the outer edges) can be ignored when playback is started near those edges (or so it seems).
I thought I was fairly safe being still on 2019.6
Old 06-29-2020, 07:41 AM
I back-reved to 2019.5 and it seems to be ok.
Randall
Randall Smith
Audio Editor/Mixer
Denver, CO
HTML code is On
2020.3 is out innesireinar Pro Tools 2020 114 04-09-2020 08:55 AM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
2020.3 Mac 5,1 stargazer Pro Tools 2020 25 04-03-2020 02:54 PM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
