Old 02-19-2020, 05:03 AM
Branko's Avatar
Branko Branko is offline
Default Dolby Atmos Renderer file naming
Hi everyone,
I'm using the Dolby Atmos Renderer for all my (offline) re-renders, but one thing keeps pissing me off:
7.1 config adds Lrs & Rrs file extensions, and Pro Tools cannot figure them out. They should be named Lsr & Rsr. Also it adds a track number to every file, so it makes it impossible for Pro Tools to recognise these as one multi-channel file.
Is there a workaround? Or I better stick to good-ole renaming?
Branko Neskov c.a.s.
www.loudness-films.pt
Old 02-19-2020, 06:33 AM
quadraphonics quadraphonics is offline
Default Re: Dolby Atmos Renderer file naming
If you export the Re-Renders as interleaved, Pro Tools does not have an issue.
Randall
Old 02-20-2020, 04:05 PM
paulo m's Avatar
paulo m paulo m is offline
Could you post this here as well?
https://developerkb.dolby.com/support/discussions
I´ll be interested in the response as well. It seems that there´s no standard to naming, I also find it annoying.Thanks
Regards,
Paulo M
Old 02-24-2020, 11:07 AM
Adam at Dolby Adam at Dolby is offline
Hi, Unfortunately there are multiple naming conventions for channel/speaker names beyond 5.1 across platforms. The numbers were implemented to assist in bringing re-renders into NLEs as well as DAWs. There isn't a perfect solution for this though I agree it could be revisited. As noted using interleaved .wav gets around the inability to import but be aware that the renderer uses SMPTE channel ordering - L, R, C, LFE, Ls, Rs, Lrs, Rrs.
Old 02-25-2020, 07:31 AM
Brandonx1 Brandonx1 is offline
Why not solve for this by having a preference for DAW or NLE that is being exported to.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 03-01-2020, 01:31 AM
Branko's Avatar
+1!
Old 03-01-2020, 01:43 AM
Branko's Avatar
Interleaved .wav files are highly impractical, very often delivered without proper documentation, and in many cases produced without a minimum of understanding the way they'll be used.
That is, probably, the main reason all distributors I've worked with always request multiple mono files, not interleaved. They also ask, in many cases, for a Pro Tools session containing all the deliverables synced to a picture.
Bearing in mind Pro Tools is the most used DAW in post around the world, it would be a nice touch from Dolby to adapt their Renderer's output to it. Or, at least, add an option to chose the destination DAW in preferences.
Importing interleaved files adds one more (annoying and unnecessary) step in deliverables production, effectively duplicating the number of produced files, increasing greatly a possibility to commit errors.
HTML code is On
Dolby Atmos Production Suite renderer on another computer nedd Post - Surround - Video 7 04-24-2019 08:11 AM
Atmos HT Renderer Norad155 Post - Surround - Video 0 04-02-2019 10:24 AM
Dolby Atmos subwoof Post - Surround - Video 3 09-11-2014 12:10 AM
Dolby Atmos peter5992 Post - Surround - Video 20 10-29-2012 01:51 PM
Dolby Atmos mikevarela Post - Surround - Video 3 06-25-2012 07:13 PM
