external ssd drive: unable to create record files for one or more tracks
macbook pro retina 2.6Ghz corei5 haswell 8Gb ram
lacie rugged USB3 120Gb SSD drive (external) PT 10.3.7 disk permissions on Lacie Rugged USB3 120Gb SSD are set to: everyone = read&write 1 guitar track 1 master track unfortunately I keep receiving the same error message when hitting te record button: "unable to create record files for one or more tracks. Check your disk allocation and drive permission". I just want to record a single guitar track, why is PT giving me a hard time? |
Re: external ssd drive: unable to create record files for one or more tracks
Are you sure you have formatted that drive as HFS+ (Mac OS Extended, Journaled, case-insensitive)
thank you for your reply.
Yes my drive is Mac OS Extended (Journaled) formatted. the thing is: it works with my iMac and the Lacie SSD drive (connected with thunderbolt) It does not work with my macbook pro and Lacie connected with USB3 UPDATE: I moved the project from my external Lacie SSD to my macbook pro SSD drive: problem remains. |
Did you check your disk allocation?
Pro Tools Menu Setups. Mac OS? Drive-Enable R in Pro Tools-workspace window?
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
In case other people come across this I've encountered it a couple of times when providing phone support. The solution has been to save and reopen the session, usually it occurs if the session has been moved while it's open.
I'm having this same error. I've used this drive for a long time with Pro Tools, but recently got a new MacBook Pro. Any ideas?
OS: 10.15.4 PT: 2020.5.0 MacBook Pro 16"/2019, 32GB Ram USB3 Hard Drive with Anker USB Adapter (which i think might be my problem)
Home: 27" iMac, (Retina 5k, 2017) 4.2GHz Intel Core i7, 32 GB RAM OSX 10.3.3 UAD Apollo 8 Duo UAD Apollo 16 silverface UAD Satellite Octo, Thunderbolt PT 2018.10 Work: Mac Pro (Mid 2012) 2x3.06GHz 6-Core Xeon, 32 GB 1333 MHz DDR3 OSX 10.13.6 Avid HDX HD Madi x 3 SSL C100 |
I cannot create a new session, I am not allowed to save in external fw800 drive | alidav | Pro Tools 10 | 4 | 06-21-2013 10:22 AM |
Unable to set my Glyph external HD to record volume!!! | gemini06 | Pro Tools M-Powered (Mac) | 1 | 07-31-2011 08:39 AM |
PT will not open or create a session on external drive | lanhet | Pro Tools M-Powered (Mac) | 1 | 10-21-2008 04:36 PM |
Unable to create new audio files | Steeb | Pro Tools TDM Systems (Mac) | 10 | 06-15-2001 10:36 AM |
unable to create tracks | Kellbert | Digidesign Hardware & Software | 3 | 03-08-2001 12:36 AM |
