Old 11-05-2010, 05:24 PM
zenabi916 zenabi916 is offline
Unhappy Eleven Rack Delay PROBLEM HELP!!!!
I recently purchased an Eleven rack and I've constructed a good lead sound using the Treadplate model. I'm trying to put delat over it but no matter what I do, no delay is being heard out of the amp.
My guitar is running into the input on Eleven Rack, a cable is running from the front output to amp to the input of my tube combo, and i have 2 cables for putting the rack through the combo's effects loop.
I've tried putting the delay in every possible place in the signal chain and NOTHING is working! Please help me!
Old 11-05-2010, 08:40 PM
Default Re: Eleven Rack Delay PROBLEM HELP!!!!
Did you turn it on??? Physical hardware button that says "delay" on the face of the rack. Mess w the controls on the delay??
In your options do you have your output to amp set to rig output no cab?
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 11-06-2010, 07:52 PM
mikefont mikefont is offline
Hey zena, I'm a little confused at how you have your rig set up. Correct me if I'm wrong, but it sounds like your signal chain is...
guitar -to- 11R guitar input then 11R "Output to Amp" -to- your tube combo amp.... and you ALSO have the FX loop of the 11R hooked up to the FX loop of your combo amp????
That sounds a little weird to me, and I wonder if it's the FX loop that is maybe having a conflict here. With the delay coming from the 11R, you don't need the FX loop hooked up to the FX loop of your amp. That's for hooking up other FX pedals! Try disconnecting the FX loop and see if that helps
Good Luck
Mike
Lenovo IdeaCentre K430 Windows 7 Pro SP1 64bit PC with 3rd generation 3.4 GB Intel Core i7-3770, 32GB DDR3, 2TB HDD, NVIDIA GeForce GT620 running Pro Tools 11.3.1 and PT 10.3.9 and the ELEVEN RACK!
Eleven Rack Stereo Delay Trouble scottya macOS 1 03-20-2012 08:11 AM
Eleven Rack Problem adflaker Windows 3 11-09-2011 02:27 PM
Eleven Rack Dyn Delay filosofem Eleven Rack 17 04-03-2011 06:22 PM
Eleven Rack/003 set up problem? Ph.D Eleven Rack 3 02-15-2011 03:13 AM
Eleven Rack Problem Päng 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-18-2010 12:54 AM
