Freeze on startup, PT 9.0.5, OSX 10.6.8
Hello all,
I'm hoping someone here can help me figure out a problem launching ProTools 9. It freezes while I'm starting it up, usually at the "Building Mix Window" stage. Sometimes if I leave it for a while (like 20 minutes) it eventually loads -- other times it just stays like that. I recently upgraded to v.9 from v.7, and I'm using a brand new iMac with 12 gigs of ram, so the computer's power shouldn't be an issue. Plugins seem to load (it freezes after this stage). I disabled the Waves TDM plugins just in case, and also repaired the hard disk, neither of which made a difference. This just started out of nowhere (I hadn't recently installed any plugins), and once in a while it still loads quickly, but it's becoming more and more rare. I'm recording with a Duet 2 onto a Glyph firewire drive. Restarting the computer sometimes works, usually doesn't. I will be eternally grateful to anyone who has an idea what to do. Thanks. |
Re: Freeze on startup, PT 9.0.5, OSX 10.6.8
We have similar issues on a PT|HD system, running on a Mac Pro. Only solution yet: Shut down completely, wait at least 30 (!) min. and restart. This occurs just once in a while. No idea, why. Support(s) could not help.
In your ulility folder you will find a program, called "Konsole". Open it and somewhere in there is a digidesign folder with log files. That will give you a idea of what happens in your system.
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB |
Startup Freeze PT 10.3.5 HD (OS 10.7.5) | lownotesinc | Getting Started | 0 | 11-14-2013 07:15 AM |
pro tools freeze at startup | dominic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 01-16-2009 12:18 AM |
PT startup freeze when clock set to external | sophie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-21-2006 11:27 AM |
Atto/Freeze at startup/933 G4/scsi 64 | patman | Pro Tools TDM Systems (Mac) | 5 | 03-25-2003 02:28 PM |
G3/300/MT Cheetah Freeze on startup problem | 2 bit | Storage Subsystems | 1 | 12-04-2000 04:32 PM |
