Old 08-24-2001, 06:09 AM
Badooker Badooker is offline
Default Dell P4 1.4ghz
I Just ordered a new dell becasue my PII350 just isnt cutting the mustard. Anyone using a P4 and run into any problems that I should know about. THe chipset is intel 850...drive is 7200rpm 256mb ram @ 800mhz ..if anyone is running same type of machine how many tracks and how many plugins r ya running....just curious!
b
rad
www.originalsoup.com [img]images/icons/grin.gif[/img]
Old 08-24-2001, 06:19 AM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Dell P4 1.4ghz
Until microsoft and practically everyone else that writes software, writes some code that takes advantage of the P4 cpu the extra cost just isn't worth it in my opinion. You won't get very much of a performance increase over a P3(and in some instances a worse performance). It's going to take quite awhile for these companies (including the audio industry) to re-write their applications to take full advantage of the P4, and by then we'll be paying a whole lot less for a P4 cpu.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 08-28-2001, 01:49 AM
hurlup hurlup is offline
if you already ordered the thing give it a go!!.......if the P4 rejects digi MAYBE???? you can hub to your old P3 to access and use protools on your new fast P4................................................ ........ CAN ANYONE GIVE FEEDBACK ON NETWORKING WITH A DIGI???
Not enough Memory - Mac Pro, 2x2.4Ghz, sonor77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-16-2010 12:25 PM
AMD Turion(TM) 64 ML-44 (2.4GHz/1MB L2 Cache meltdown5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-07-2006 04:53 PM
Mini 1.25ghz vs P4 2.4ghz CrAkD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-24-2005 04:58 PM
P4 3.4Ghz compatibility problems! pete66 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 39 01-26-2005 10:06 PM
VIA KT266 AMD 1.4ghz oslpchris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 10-26-2001 07:10 AM
