Idle Digi 001 running at 100% CPU usage in XP Task Manager Help
When the Pro Tools application is open the CPU usage in Windows Task Manager shows 100% how can I fix this problem. I can only get about 6 tracks on the DAVEC test. Please help.
Thanks Ajay |
Re: Idle Digi 001 running at 100% CPU usage in XP Task Manager Help
100% usage in the Task Manager is normal....6 tracks DaveC is not...
I am sorry i cant give some tips, but you have to tell a bit more about your system.... what mobo, processor, harddisks? what applications are installed? what OS are you running? (winXP i think because of the task-manager...) other installed hardware? irq-listing?
What's that? - That's the machine that goes "pling". Bastiaan |
A7V333-X rev 2.01
IBM Diskstar 60GB C Drive WD 80GB 8M Cache D(Audio Drive) Drive Leadtek Ti 4400 Two Samsung 512 sticks (but they look different) Swiftech 462 U Cooler (Very Good) Lite On 52-24-52 Throughbread 2100 BIOS 1003 IRQ 0 System timer IRQ 1 Keyboard IRQ 6 Floppy disk controller IRQ 8 System CMOS/realtime clock IRQ 9 ACPI Compliant System IRQ 12 Mouse PS/2 IRQ 13 Numeric data processor IRQ 14 Primary IDE Channel IRQ 15 Secondary IDE channel IRQ 16 GForce Ti 4400 IRQ 17 Digidesign Digi 001 IRQ 18 ASUS Broadcom Lan IRQ 21 Via USB Rev 5 or later IRQ 22 Via AC 97 audio controller Adobe 5.0 Quick Time Norton Antivirus 2002 Symantec Live Update (Norton) ASUS Update XP Pro No Other hardware The two hard drives were on the same channel one as the master and the other as the slave and even when I put the drives on seperate channels it made no differenc. I even tried it with one stick of 512 RAM and nothing. Any help or info you could provide Bastian would be greatly appreciated. If this is not enough info please let me know and I will provide the information you need. Thanks Ajay |
Make sure you disable your antivirus or PT will barely run.
Also make sure qttask (quicktime) isn't nunning in the background. It's a system hog. |
The system was lagging before I ever ran these programs.
Ajay |
you cannot find peace by avoiding life |
Thanks for the input on the CPU usage, but does anyone have any suggestions on how to get 32 tracks on the DAVEC Instead of 6. Bastiaan where are you? Help.
Ajay |
I have an XP 1800 and get 32 + 2 aux's. With antivirus running, I'm lucky to get a session open. DMA enabled on your drives? System sounds and "eye candy" disabled? What programs are running behind 001? Have you tried disabling your LAN while in PT? |
Hi Ajay-
No, I'm not running Norton, E-trust by Computer Associates, which is by far much less intrusive than Norton or Mcafee. (I've had experience with all three. Mcafee is the worst. Like a boat anchor.) Digidesign specifically reccomends disabling any antivirus (as well as other suggestions)in the 5.3.1 Addendum pdf, page 4. Your IRQ's look OK... it seems to me you have some program choking your system. Might also try replacing the VIA IDE controller drivers with generic M$ ones. Sorry you're still having problems. |
Task Manager | Cal D | Pro Tools M-Powered (Win) | 0 | 02-10-2011 08:45 PM |
Task Manager | SKYHIENTERTAIN | Pro Tools TDM Systems (Mac) | 6 | 10-28-2008 11:13 AM |
Eratic CPU usage at idle. | Blank Frank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-02-2007 08:59 AM |
cpu usage maxing out even when idle | SoFar1 | Pro Tools M-Powered (Win) | 3 | 11-21-2006 10:54 PM |
open task manager when running PTLE, how much CPU is PTLE supposed to take? | Steven5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-30-2002 08:10 AM |
