Old 05-18-2020, 05:07 AM
PhilCurry PhilCurry is offline
Default Lost files and can't record.
Hi, I've recently begun using Protools and have so far completed two projects. However, when I opened Protools ready to re-record a bass line last Friday I discovered that all my audio files had been lost (luckily, I had previously bounced the tracks down to mp3).
This is what happened next so I hope someone can provide a solution, as for the moment, my investment in Protools is useless.
1. A 'regenerate files' window appeared. I clicked this and some files regenerated, but two were still missing. I tried opening other versions of the same project, only to discover that in some of them, [U]all[U] the files were missing,
2. I went back to the original project and decided to re-record the bass line over the greyed-out missing track. A window appeared saying 'no record volumes designated'.. I didn't know what this meant so I Googled it. The suggestion was to " “Check Disk Allocation and be sure that all tracks are pointing to the correct drive”. I don't know what this means. I checked disk allocation and all the tracks were there but when I clicked on them all that appeared was a notice saying "In input 1 (mono).
3. I went back to my tracks again and noticed that in the I/O dropdowns, instead of Input 1, it now said 'In input 1 (mono) and the same message about no record volumes designated.
On Friday, I tried uninstalling and re-installing several times and even deleted Protools from my computed and re-downloaded. Then I gave up.
Today, I opened my Protools files to try again and the same issues arose. What's more I have now lost every single audio file on every version of the main projects I have worked on over the past month.
I hope someone can help. As I said above, for the moment my investment in Protools is useless and all the work I had done on the album I was recording has disappeared. I'm not happy.
Old 05-18-2020, 07:57 AM
Ben Jenssen's Avatar
Default Re: Lost files and can't record.
Hi. Welcome to the community.
You must provide as much information as you can, before anyone can help you.
Start here:
Help Us Help You
Old 05-18-2020, 01:19 PM
When you say "Projects", are you talking about a "Session"(which lives on your computer) or a "Project"(which lives in the cloud)? If it is indeed a project, maybe its an internet issue or maybe a login issue?
Signal Lost intermittently while In Record. stringbassist macOS 3 01-30-2019 11:32 AM
Pro Tools 12.6 not copying audio files on import! = Lost files DJ Hellfire Avid Pro Mixing General Discussion 2 10-07-2016 07:27 PM
lost ptx files stics1976 Pro Tools 10 5 02-24-2016 03:49 PM
Why do i lost files? kalony 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-13-2008 09:21 AM
Lost files and renaming files GoneIndie Pro Tools TDM Systems (Mac) 2 01-13-2005 07:08 PM
