Old 09-06-2013, 03:15 AM
eddie lamb eddie lamb is offline
Default protools 11.01 close session crashes on load next session
i've moved all non pt plugs into the unused folder but still when i close session protools 11.01 crashes or hangs on load next session ( since i updated to pt11 0.1 ) . only the first session will open , any subsequent sessions and pt11 becomes unresponsive and will not load . shift open will not open the second session either . now i can still work on one session close pt11 and work on another of course but it would be nice to solve this problem . i don't see anyone else with this problem so i do hope i'm not alone . Ed
Old 09-06-2013, 03:50 AM
demodigi demodigi is offline
Default Re: protools 11.01 close session crashes on load next session
Hi eddie,
I sometimes have crashes too with Pro Tools 11 but not so often.
Do you have "WaveCache.wfm" file into your session folders ?
Quit Pro Tools and try to put those files into the trash (it is a temporary file so no damage will be done to your system) and re-open Pro Tools and your sessions.
If it doesn't work, take a look at the troubleshooting page
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD)
MacMini (Core i7 Quad@2,3GHz RAM16GB SSD)
PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP)
PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP)
PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD)
PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD)
RME UFX (USB2 with MM and Firewire with MBP)
+ Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1
Old 09-07-2013, 01:51 AM
Thanks . i should have mentioned i am a windows 7 user . i'll try trashing waves cache . thanks again . Ed
PT's crashes after I close a session D'Animation Pro Tools TDM Systems (Mac) 5 06-24-2011 09:52 AM
PT 8 crashes on close, old session - crash log incl jaguffain Pro Tools TDM Systems (Mac) 6 02-14-2011 09:38 AM
Pro tools 8 crashes when i close a session Raoul23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-19-2009 03:35 PM
PT 7.0 crashes when I load a particular session phentalmyst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-08-2006 11:58 PM
Guitar Rig 2 causing "close session" crashes nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-08-2006 05:31 AM
