Old 02-09-2012, 12:06 PM
OneStrat OneStrat is offline
Default Firmware update 2.0 to 2.0.1 fail. What now?
I never updated my ERXP from build 0.1.5.3 to 0.1.5.7. I never had an issue with the original install and figured if "it aint broke, don't fix it". Today I attempted to do the update(slow day here :)) and got the "1 seat used" message. Same computer used for the original install, Pro Tools 9 working with no problems, downloaded the firmware update file from my Avid account, entered my serial number and ID in the proper fields and got the fail message. What do I need to do now to get this update to work? Any help would be appreciated. Thanks
Old 02-09-2012, 02:07 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Firmware update 2.0 to 2.0.1 fail. What now?
It may be the same computer, but have you updated the OS on the machine?
What OS?
If Windows, then make sure to uninstall IE9 first.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 02-09-2012, 02:55 PM
Thanks for the reply Benoni. I'm using the same computer with Windows 7 and IE8. The only changes have been the usual Windows updates, but nothing like a HD format or Windows reinstall. Like I said, since everything has been working well I didn't want to tweak anything. Maybe I should stop while i'm ahead.
Old 02-10-2012, 09:13 AM
Benoni's Avatar
As long as the S/N and ID code were correct, and you did not (perhaps inadvertently) delete the hidden files that allow the ERXP Firmware updater to run again - the problem probably lies with Avid.
Not sure if you remember, but the Auth process was a cluster truck for many people. They would buy the ERXP then be greeted with "Code Already used" errors. Avid 'fixed' the problem, but days later it started happening again.
So - what I am saying is after you double check your end and confirm all numbers were entered correctly and you are connected to the net - if you still cannot update to 2.0.1, you need to contact Avid.
You should for sure install 2.0.1 as it fixes an issue.
I hope Avid rethinks their protection scheme next time. There are better ways to protect your products without making it a pain in the @ss for paying customers.
Just email or call Avid, they will fix it for you.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 02-10-2012, 02:04 PM
Resolved! Thanks Benoni.
I called Avid support and they issued a new set of codes to update to firmware 2.0.1 The update installed without any problems! I'm good to go.
Benoni, you da man! Thanks again my friend.
Old 02-10-2012, 02:17 PM
Benoni's Avatar
So i guess the problem with the server that was 'resolved' about 3 times now, was not really resolved.
oh well, at least you are up-to-date now.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 02-10-2012, 07:53 PM
zedhed's Avatar
zedhed zedhed is offline
LOL
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
OSX 10.8.5 update caused my iLok to fail? Jeff D. macOS 0 10-01-2013 10:35 AM
Mbox dimmed lights after fimware update fail jaykeating0 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-17-2012 10:38 AM
Structure Update Mac... Fail Shifted Music Virtual Instruments 42 08-14-2010 07:20 PM
Firmware Update HELP. My 003 Rack will not update Firmware. New003RackUser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-17-2007 09:01 AM
MIDI don't work & DAE fail after update 6.1.1 mly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-29-2003 06:51 AM
