Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 05-22-2020, 06:28 AM
superd superd is offline
Default Fasttrack Pro Bitrate / Format
Folks,
Im trying to stream to facebook via my fast track pro 2 sound card, and the audio is pretty bad. Ive been advised to drop the bitrate in the midi settings to 2500hz, however on my macbook the lowest i can go is 8000hz. Is there any way to drop the bitrate lower then 8000hz?
And maybe a question for apple techies rather than m-audio.. cheers.
Old 05-22-2020, 08:19 PM
Top Jimmy's Avatar
Default Re: Fasttrack Pro Bitrate / Format
It sounds like you’re talking about sample rate, not bit rate. A 2.5kHz sample rate would sound very muddy with no presence or definition. I suggest you leave the interface sample rate at one of its hardware supported rates (ie 44.1, 48) and go find the video and audio encoder settings where you can find the compressed bitrates for both video and audio. I don’t use it but I expect it’s somewhere in the Facebook live streaming settings.
James Cadwallader
Old 06-04-2020, 08:27 AM
Thanks James, apologies Im only seeing your response now, much appreciated. Ill check that out, but i believe theres very little config available on FB Stream.
Old 06-12-2020, 01:40 PM
Guys, ive been advised to adjust the buffer size on mac / fasttrack pro. Is that possible? I cant see it in audio settings.
Old 06-13-2020, 07:47 AM
For anyone that might encounter the same issues, i changed the sample depth in the m-audio settings in preferences from 24 -> 16, sounds perfect.
Thanks all.
Old 06-13-2020, 11:22 AM
Top Jimmy's Avatar
James Cadwallader
What bitrate when using Transfuser Southsidemusic Pro Tools HDX & HD Native Systems (Mac) 6 02-02-2012 06:07 AM
Bitrate question syed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-04-2007 02:21 AM
What bitrate do i set my Digi002R to? KDK Twelve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-01-2005 10:57 AM
MP3 bitrate and Tag Type jlnelson19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-12-2004 05:46 PM
AES output bitrate on 888/24 wiz Pro Tools TDM Systems (Mac) 9 07-11-2000 11:18 AM
