Custom Groups, Can it be don on an 8 Fader D-Command?
I'm trying to follow the instructions for creating a Custom Group but the instructions differ from the behavior that the D command actually displays.
My manual is ver 7.0 did something change since then? when I push the Groups button the faders go into CF mode. How to I choose members of a Group? Or is this a feature reserved for the 24 fader version? |
Re: Custom Groups, Can it be don on an 8 Fader D-Command?
On a 8 channel D command You'd have to set the pref for the number of faders that the CF group will take up. If it is set to 8 then obviously it is going to 'eat' away all your faders.
Set it to 4 and start from there. You can set it to a fixed amount (blocks of 4 on a D command I believe) or a minimum 1 to maximum 'x' amount in which a CF group will take up the number only the number of members you assign to it up to a 'x' maximum, after which it will 'bank' inside the CF group. You can set the prefs for the CF's in the soft keys section. Chris
Chris Lambrechts Applications Specialist- Live Sound |
Thanks Chris! I'll give it a shot.
adding channels to custom fader groups | corym | ICON & C|24 | 3 | 11-13-2017 04:38 PM |
Renaming Custom Fader Banks (D-Command) | legasafe | ICON & C|24 | 1 | 11-24-2009 02:06 AM |
D-Command Custom Fader question | macaholic | ICON & C|24 | 7 | 03-25-2009 05:27 AM |
Renaming custom groups ?? | Redhouse_Janke | ICON & C|24 | 2 | 12-13-2007 12:42 PM |
Custom Fader Mode on D-Command (TURN OFF) | EvanScottSmith | ICON & C|24 | 1 | 01-31-2007 04:07 PM |
