I'm getting beeps and clicks at the end of every file I record. The bump in the wave form is visible. I've re-installed software, then run Digi Test which passed. Digi tech support said that it might be a hardware failure. I hope not. Everything seems to be working fine except for these beeps clicks and pops at the end of every take which I have to trim back. Any suggestions? Thanks...
Have a great day..... Bill ---------------------- Mac Mini (2019) 3.2 Ghz - 6 Core i7 Mojave with 64 GB RAM PT Ultimate (2019.10) Motu 16a C/24 Control Surface |
Forgot to mention: PT 6.9.1cs3
Not just you ..... Not a hardware failure ....
DIGI, I just updated a few days ago .... I am working on 70+ cinematics for a video game (under a tight deadline of course) and finding that 20% - 50% of my Mixdowns (Not Bounce to Disk) to my record track have this phenomenon. It seems to be a buffer hiccup when the recording stops more than a pop or click. The work around that I have found is to add a bit of Post-roll to the end of the record. This was not happening in 6.9.1 cs2. Specs: PT 6.9.1.cs3 HD2 Accel G4 Dual 1.25 2GB ram OSX.3.9 192, Sync IO Audio on 10k SCSI drive Mixing to Stereo Track. Please look in to this. Thanks,
.: phil kovats .: audio director .: naughty dog |
FWIW, I've had this happening since 6.9cs1 at least. Does not seem to happen with ADC off, but that creates a host of other problems (partially documented in another current thread on DUC regarding regions printing EARLIER than recorded).
@wildhoneymusic http://kidzbop.com/music/ http://razorandtiemusicpublishing.co.../gary-philips/ |
Thanks! Glad to see I'm not alone and that I don't have to do what digi said to do which was to take my whole system apart and check each card out one by one (and if that didn't eliminate the problem, then digi said to pull out my ram and check each pair of ram sticks!) I'm really not up to going through all that work for nothing. BTW - It's not happening when I bounce to disk either. Anyone else experiencing this phenomenon?
Me to. Everytime I record to a track there is a spike right at the end of the file. Been happening since 6.9.
OSX10.4.2 HD Accel 2 DPG4 867 PT 6.9.3cs2 |
What has Digi told you guys to do about this?
Anybody else experiencing this?
I hate to go back to the old standard, but have you tried trashing prefs and database files as well as making sure all energy savers/screen savers and wireless/airport/bluetooth devices are disabled?
If you create a new session and record a single audio track without any plug-ins, do you still get the beeps/clicks? Does the same thing happen if you create a new admin account, sign in under it and try the test again? |
If you are recording with ADC enabled in the Playback Engine, try turning it off when recording. Alot of us here have experienced an issue with this while recording with ADC. not sure if this is your problem tho. Theres a few threads youll find if you search ADC + Pops + clicks.
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
Clicks and pops when trying to record. | A1rstudios | Pro Tools TDM Systems (Mac) | 3 | 07-27-2013 11:12 AM |
002 rack "clicks" and Windows beeps when "Setting Up Midi" or | sw0mgt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-03-2012 04:42 PM |
Digital Clicks | Wav file submitted | BelaDMedia | Pro Tools M-Powered (Win) | 5 | 03-11-2009 09:58 AM |
Clicks/Pops on record at 96K | Snitz | Pro Tools TDM Systems (Mac) | 6 | 12-04-2006 05:06 AM |
AMIII record clicks | oxygeno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-16-2001 02:50 PM |
