Bounce question (is this a bug or a feature)
Did some real simple vo stuff recently only to get burned in the end. Mono VO track Mono Master Fader. Few basic plugs on mast fader ie comp limiter. Everything sounded great. No overs. 888 CH 1 & 2 are hitting just bellow 0db. Bounced to disk (mono file) only to find all files are clipped. My digi rep sez this is the way it is and the work around is to pan all material to one output before the bounce. Now I'm listening to everything out of 1 speaker. It seems the mix bus is combining Outputs 1 & 2 on the bounce. This is very misleading and cost me some valuable time on a late Fri afternoon w/ deadline looming. What's up w/ this bug - feature? Live and learn baby - sometimes the hard way!
DS [img]images/icons/rolleyes.gif[/img]
Doug Sjostrom |
Re: Bounce question (is this a bug or a feature)
Doug -
Why not just use a stereo master fader and have your mono tracks panned to center? When you burn to CD, you effectively get a two-chanel mono representation. Regardless, the way I work around the mono listening thing is to hit the MONO button on my board. Hopefully your board can do this [img]images/icons/rolleyes.gif[/img]. Hope this helps! Bruce |
We've run into the same thing, but our Digi help was not as thorough as yours.
Thanks for the tip! - Loomage [ June 22, 2001: Message edited by: loomster ]
Chris Sound Designer, Mpls. |
Bounce feature suggestion | spliffonius | Pro Tools 9 | 1 | 05-12-2011 02:45 PM |
Bounce to Quick time new Bug / Feature ? | SOUNDDECISION | Pro Tools TDM Systems (Mac) | 1 | 09-11-2009 09:06 AM |
Feature Request: Quick Bounce! | Delta Dreams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 04-17-2007 11:24 AM |
Help with "Bounce to Disk" feature for a new user | BalSagoth6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-06-2004 09:24 PM |
Feature Request: Bounce to Disk... | Michael Coyle | General Discussion | 9 | 06-25-2003 09:25 PM |
