Old 04-13-2018, 10:57 AM
MixerGuy MixerGuy is offline
Default Batch Clip Rename not renaming audio files - just clips PT 2018-3
Woah - hold on - just discovered a potentially huge issue...
Batch Clip Rename is not renaming audio files - just clips - in PT 2018-3. Mac. Sierra.
and AFAICS there is not an option / preference anywhere.... unless I have missed it.
I print mixes all in one PT mix rig, and this is a huge problem if I print stem mixes plus full mixes, all in one pass, then use Batch Clip Rename in PT to rename my mixes.... i DO want it to rename both clips and audio files.
as of right now - it is not renaming audio files. Just checked.
thoughts?
thanks.
Old 04-13-2018, 03:04 PM
kkfaudio kkfaudio is offline
Default Re: Batch Clip Rename not renaming audio files - just clips PT 2018-3
Yep, that’s how it works..
My process is batch rename the clips, and then select all of them and hit regular rename, and keep hitting “enter” to rename the actual file..
I’d love to see a preference to do the whole file...
Kevin Ferrier
Audio & Sound Design
www.jaxxcreative.com
Old 04-13-2018, 05:41 PM
That is completely crazy (and nuts) that it isn't a preference or a tick box to have it rename the actual audio files as well.
thanks .
Old 04-14-2018, 10:20 AM
Does anyone else want this to be a preference or a tick box?
Old 04-15-2018, 04:59 AM
Drew Mazurek's Avatar
The issue I see is that since sessions can share the same files, even across networked storage, one user changing file names could wreak havoc in a multi room facility with sound FX libraries etc.
www.drewmazurek.com
Old 04-15-2018, 06:50 AM
its2loud its2loud is offline
There’s an easy workaround if you’re delivering individual audio files. Just export the clips as .wavs and they’ll carry the name of the clip, not the actual file name.
Old 04-15-2018, 07:00 AM
BScout BScout is offline
That “issue” should be left to the user. (Like file naming in the first place) I too believe it should be an option and find that it being missing annoying. I understand they were really pitching this to game audio developers where there’s a workflow of clip rename and export but for a lot of us, this restriction slows down the effectiveness of this “time saver”. It also doesn’t help that advancing to the next clip with multi-clip/file rename has gotten slower — which has been the workaround to commit batch clip renames to file names.
I also understand that the lack is because of mixed highlighting/renaming could result in some clip renames and some file renames which could be confusing. Still find that Avid should trust the user.
As for networked/shared SFX libraries, I have no idea of a facility that has libraries like this for multiseats who do not enforce that a local copy/transfer path has to be used — for some very obvious reasons. It would be extremely short-sighted if such a facility exists.
Old 11-07-2018, 01:37 PM
rpalagy rpalagy is offline
Without a doubt we need a checkbox to allow us to rename actual files. Leave it up to the user.
Old 11-07-2018, 07:41 PM
cwsand's Avatar
cwsand cwsand is offline
I agree.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-07-2018, 09:43 PM
This really is one of the big annoyances.
I'll go through 300+files a week of renaming that I have to do the two steps of batch rename and then rename again just to make it transfer to the file name.
And the "committing" step is so slow because Pro Tools can't keep up with just hitting "Return" to go to the next file.
Batch Renaming only renaming clip, not disk file polyh3dron Pro Tools 2018 3 07-28-2019 10:15 AM
PT12 Clip Rename not working for newly recorded clips Channel time Pro Tools 12 3 02-23-2018 01:22 PM
Clip Gain and Export Clips as files Farmer Dave macOS 2 03-18-2012 10:48 AM
Batch Renaming App minister Pro Tools TDM Systems (Mac) 4 08-10-2006 09:14 AM
PT 7 Renaming and why it doesn't rename regions Dan Pinder Pro Tools TDM Systems (Mac) 4 11-08-2005 11:16 PM
