Old 04-23-2010, 09:31 PM
awthentik83 awthentik83 is offline
Default FIREWIRE problem with new iMac 800 to 400 cable
I saw some forums on this but none with the same problem i am having.
Just got a new Imac 27 inch running Snow Leopard with protools 8 and a digi002 rack. Im not a newbie to protools. PT8 works great when I hook up my friends mbox 2 and the software reads the hardware just fine. But when i try to hook up my digi002 rack, it just doesn't recognize my hardware at the startup protools.
I KNOW THE 002 RACK WORKS because it works fine on my older mac-book. But when I hook the 002rack to my iMac it doesnt recognize the hardware.
I am using a firewire 800 to firewire 400 cable because the iMac only has a port for firewire 800. My cable is one that came with a western digital hard drive so im skeptical about that
Could the cable be the issue ??? I know the firewire port on the iMac is ok because I have hooked up a hard drive to it. Thanks in advance for your help
Old 04-23-2010, 09:58 PM
Sardi Sardi is online now
Default Re: FIREWIRE problem with new iMac 800 to 400 cable
Try placing a FW400 drive in the chain. iMac > FW400 drive > 002. Does that work?
I've seen numerous people using an 800 - 400 cable direct to a 002/003 without issues. Could be the cable. Try one of those Belkin ones and see if it works direct.
Which Firewire Cable 6 or 4 pin? to iMac jiagap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 04-16-2010 08:28 PM
Firewire cable problem Soondot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-02-2009 08:40 PM
Unable locate 003 rack - firewire cable problem? Wesselink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 28 06-06-2007 11:40 AM
DIGI002 firewire cable/port problem danielpetry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-11-2007 06:24 AM
DIGI Firewire Cable Was the Problem! DBro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2006 02:48 PM
