Old 11-07-2011, 02:49 AM
dalaolv dalaolv is offline
Default 2.6.2, win 7 64bit, protools hd 8.0 couldnt regonzied eucon
hi all, just switch my mc mix from G5(Leopard) to win 7 64, problems are listed:
i installed 2.6.2, upgrade the firmwire, avid icon shows on mc mix screen, connected mc mix and pc, after 30 second, mc mix was recongized by eucon, then i opened protools hd 8.0, go to setup---perperhensal---ethernet----scan----no eucon was found!!!!, tried upgraded to protools hd 8.04, same result.
after a few times restart,(i installed some software during the process) two diolog windows appeared when system start:
1.eucon network services could not be started
there was a problem with current network configuration that could not be resolved,please check your net work setting and connections and try restarting the cucontrol application, if that doesnt work, please restart your computer.
2.mc_client detected a network problem and will now exit,please check your network setting and connections
bad or null corba poa.
then i restarted the computer, same result.
equip:
euphonix mc mix I,asus motherboard p8z68-v, i3 2100, 2G kingstone ddr, 192/io,HD2 pci-x (process).
thanks a lot for concern and looking forward to answer!
Old 11-07-2011, 06:43 AM
jesse p jesse p is offline
Default Re: 2.6.2, win 7 64bit, protools hd 8.0 couldnt regonzied eucon
Upgrade to 9 or 10 if you want to use Eucon
www.kdsound.net
Sound for film and Television
Old 11-07-2011, 07:34 AM
klaukholm klaukholm is offline
You will have to connect via HUI mode in PT8
I strongly suggest you upgrade to v10 if you have a eucon enabled controlsurface
No Eucon commands visible in Eucontrol software 2.6.2 (Win7 64bit, PT 9.0.5) Elmobe Artist Series 0 11-23-2011 02:35 AM
when will there be a 64bit nuendo eucon adapter? pitz System 5 1 02-25-2011 03:57 AM
Eucon -> Protools TVPostSound Artist Series 38 10-13-2010 12:44 PM
k somehow i couldnt find this craiz730 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-09-2003 12:26 AM
help! couldnt find link Basshead3606 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-05-2002 08:15 PM
