#41
Re: PT12 - "freeze track" feature
+1
#42
So all of your other processing and automation can stay active on that track. In place. If you wanted to print the VI but keep the EQ and Compression on that track adjustable, you can still do that. Or you can print it all. All an option. But the most important part of Track Freezing is Track Un-Freezing. Let's say that you had 80 tracks of VIs and you printed them with your method. Two weeks later they tell you in needs to be in a different key. With your method, you need to FIND each track that goes with the print (they don't stay together just because you hid them) and do it all again. And copy your new automation (the stuff you made after you froze things) to the new tracks. With track freeze, you select all 80 tracks, select unfreeze, transpose the midi to a different key and then re-freeze. That's it. You don't know what you're missing because you don't have it.
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
#43
Thanks Kenny. I sure this will help those who haven't explored the significance of Track Freeze. I just hope it arrives sooner rather than later.
#44
Due to reaper's handling of media, their version of track freeze will not be the same as Pro Tools.
Reaper tracks can have both audio and MIDI on the same track, and can output MIDI or Audio arbitrarily - instead of Pro Tools, where MIDI tracks can't output audio and vice-versa. So a reaper track doesn't care if it started out as MIDI feeding a VI, you can freeze it to audio on the same track and everything will work out. This isn't the case with PT. Which again brings up the question of sends handling when freezing tracks in PT.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#45
Of course if you want to "freeze" a more complex arrangement of tracks feeding various aux sends there is always the option of doing an offline bounce, which has the flexibility to allow more complex routing situations to be bounced, or a realtime bounce if live inputs or analog outboard inserts are being used.
Steve Peach Stereo Missile Recordings Creative Director - Red Note Visionary Sounds: http://rednote.com.au Label: http://www.stereomissile.com/ Music Production / Mixing: http://www.stereomissile.com/musicproducer/ Mastering: http://www.stereomissile.com/mastering/ |
#46
#47
#48
At the NAMM presentation, there was also a "Commit" function. We will need to know more about exactly where one leaves off and the other picks up. I's my guess that the above workflow will be covered.
#49
That's pretty much how Samplitude does it. In an audio track the audio is frozen with track FX applied, but the Sends and Aux's are still fed by the frozen audio. The same is true with instrument tracks. The audio is frozen as if played from the MIDI playing it, and Sends and Aux's are still fed from the resulting audio.
Dean Quote:
#50
Obviously you should stick with Avid then. No need to change.
offline bounce from Send or Track outputs - track "freeze feature" | OliverH | Pro Tools 11 | 20 | 05-25-2014 04:45 PM |
Freeze when "Some paths were made inactive..." message appears (10.3.6) | SlicerSounds | Windows | 1 | 07-07-2013 10:20 PM |
Toggle Track view ("Opt"+"-") doesn't work | LukeFromBerlin | macOS | 3 | 04-01-2012 04:43 AM |
If I "Remove Unused Regions" after "Consolidate", track won't play? | el biciclista | Pro Tools TDM Systems (Mac) | 10 | 04-02-2003 10:17 AM |
Problem "apparently" finally solved; No more mouse freeze! | dkrausz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-15-2002 08:00 PM |
