Re: PT11 keeps freezing
Thanks for all the quick responses guys! Downloading 11.3 now, I'll update and see how it goes! I'll keep you posted.
Loving PT by the way! Bought it and didn't open Logic Pro ever since
Macbook pro (mid 2010), 2.4GHz, 8gb RAM, Osx 10.10.1 PT11 Apogee Duet2 Waves |
Downloaded the update, run the installer, rebooted.. First try, nothing. It started on the second try though but it's still weird that it has this problem.
Any more ideas?
This page says that your operating system 10.8.5 is the oldest supported by 11.3 so while it should work you might have better luck with Yosemite. If everything else you have is supported on Yosemite, that upgrade is something that I think you should consider.
That would be an option although I'm not very pleased with that.. Everything worked perfect up until this point but hey, I guess I'll have to give it a try. Thanks!
Sooo, everything is up to date but it's still unpredictable. I want to contact someone of avid's tech support, how do I get there fastest?
#16
Shameless bump.. Can it be a hardware problem? I'm using a mid 2010 macbook pro, see the specs below, is it time for an upgrade?
#17
BTW OSX 10.8.5 runs PT11.3.0 no problem here; ditto for OSX 10.9.5 |
#18
Wireless is on and some other small stuff going on in the background but nothing serious.. A macbook should be able to handle this right? Not trying to use anything illegal in case you guys were wondering. Some waves plugins that I bought, nothing more..
Did a clean install, didn't install the AIR plugins and it seems to be working better today. Not sure if I'm lucky today or PT really is working as it should Any known problems with AIR plugins..?
#19
... small stuff going on in the background ...
Problem is, you never know when the small stuff might grab a resource just before Pro Tools needs it. And if Pro Tools needs it and can't get it, you've got a problem. And don't forget the proverbial "camel's back"...sometimes even something small can put you over the line...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
#20
So what you're suggesting is basically shutting everything down off before opening PT? Seems a bit drastic but if it works, it works. Try that for a while, thanks.
PT11 file unreadable by PT11 | Nayon | Pro Tools 11 | 11 | 09-12-2014 06:50 PM |
Help!!! PT11 freezing every time I save | studioj11 | Pro Tools 11 | 2 | 04-29-2014 09:15 PM |
PT11 Timeline Freezing During Recording | thumos | Pro Tools 11 | 0 | 12-22-2013 02:47 PM |
PT11 to PT11 HD Native upgrade without hardware? | kirkbross | Pro Tools 11 | 2 | 11-04-2013 03:10 PM |
Pro tools SLOW, and Freezing then continuing, then freezing again | DJX-RAY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-09-2011 07:52 AM |
