misbehaving 003 please help
Hi
I have a 003 on a mac running os x and pt 9. It was fine yesterday but when I booted up today the host 1394 light on the front was flashing (- the one on the rear of the unit is solid) and protools cant find the 003. Interestingly enough system preferences on the mac can find it so i'm figuring it might not be the firewire - although I cant get itunes to play through the 003 either. So far I have rebooted (several times) and I have swapped the cable between the firewire ports at the back of the 003 (with it off!) but to no avail. Any help gratefully received. Thanks |
Re: misbehaving 003 please help
Try re installing the drivers. Make sure you have latest drivers from here and install with 003 turned off, then reboot with it switched on and you should get a message saying windows is installing drivers then "Your Hardware is Ready to Use".
http://avid.custkb.com/avid/app/self...3=1450&Hilite= You may also want to try a different firewire port but DO NOT hot wire. Make sure computer AND 003 is turned off when connecting/disconnecting firewire cable. Also try reinstalling firewire drivers. Control Panel>Device Manager>IEEE 1394 Bus Host Controllers. Double Click on controller>Driver Tab>Update Driver>Search Automatically. Do this for each controller listed. The above instructions are for PC so you'll have to translate method to Mac.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Thanks Zed tried installing drivers and now they are upto date but the host light is now permanently off.
my computer can see the 003 (in settings) but protools cant. eek....... |
Its the firewire chip. Guarantee it.
Send it back for warrranty work. If no warranty, PM me know several folks that can replace it for far, far less than a new FW card. Last check replacement was about 400$
Mac Pro, Snow PT 10HD,Sequoia, Reaper W7/64, PT 9HD,Sequoia, Reaper 192 HD, HD-N, 002C BLA, BLA AGB,Autuer,Lucid, MicroCLock, Pultec, UA, Sebatron, Focusrite, Trident,API, A-Designs, Purple Audio
When you say that PT cannot see the 003, what exactly do you mean? When you got to playback engine, is the 003 listed as the playback device or is it set to aggregate or one of the other settings?
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Misbehaving busses!! | Alejandro R | Pro Tools HDX & HD Native Systems (Mac) | 1 | 05-23-2013 03:58 AM |
TL Rehab misbehaving in 8.1 | crizdee | Pro Tools TDM Systems (Mac) | 2 | 08-26-2010 11:40 PM |
002 misbehaving on 10.5.7 | topperf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-11-2009 05:20 PM |
SampleTank is misbehaving | LiamSlack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 04-10-2008 08:57 AM |
002r Misbehaving | mfb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-27-2007 01:03 PM |
