Old 04-27-2004, 08:03 AM
JT916 JT916 is offline
Default expansion chasis help?
I got the older DD007-R 32 bits 7-slot expansion chasis. I want to use this with my HD Accel system. Does it make any different using the 32 bits verse with the Magma 64 bits expansion chasis?
thanks
jt
Old 04-27-2004, 12:26 PM
Kelly M. Pieklo Kelly M. Pieklo is offline
Default Re: expansion chasis help?
Got this from the Answerbase:
No, there is no need for a 64-bit chassis with Pro Tools|HD. We did qualify the Magma 64-bit chassis as part of our research and development effort, but we also qualified the two Digidesign chassis - both of which are 32-bit. So far, we have not seen any marked improvement in performance with a 64-bit chassis for Pro Tools.
For all compatibility information:
http://www.digidesign.com/compato/
kp
"I don't feel tardy." - DLR
Old 04-27-2004, 12:28 PM
Sorry - I realized that the question is regarding HD|Accel, not just HD.
kp
Old 04-27-2004, 12:37 PM
ripple FX ripple FX is offline
I am successfully using the DD023 13 slot chassis with HD3.5 (That is 1 HDcore, 2 HDaccel, 1 HDprocess).
I believe there is reduced track count at 192KHz SR using any chassis.
Cheers,
Chris
http://www.ripplefx.com
Mac Pro 8 core 3.0GHz Harpertown
Magma PE6R4I - HD 3 Accel +1 Process
Control 24 - 96io - 1622
OSX 10.6.8 - PTHD 10.3.10
Old 04-27-2004, 08:40 PM
Danny Caccavo Danny Caccavo is offline
This page should answer your questions.
http://www.digidesign.com/compato/osx/hd/expand.cfm
Danny Caccavo
Digidesign
Old 04-27-2004, 08:52 PM
roberts roberts is offline
I can say for absolute sure that a 64 bit chassis works a Lot better in a G4 for Accel than a 32 bit chassis.
First I had 2 - 32 bit chassis SBS and a Digidesign/Magma. Both Worked OK for my Accel 7 system. But when I changed to a new 64 Bit Chassis it made a huge difference the PCI indicator went way down, Sessions that could hardly play on level 8 played at level 4 no problems. DSP loads faster too. I have a Dual 1.4 G4 and I love the 64 bit chassis it's worth every penny.
Old 04-28-2004, 09:57 AM
Bambison Bambison is offline
I can say for absolute sure that a 64 bit chassis works a Lot better in a G4 for Accel than a 32 bit chassis..... Sessions that could hardly play on level 8 played at level 4 no problems. DSP loads faster too.....
Roberts, can you tell me the general track count of the sessions and plugin usage. I'm trying to help a friend who's facing a similar problem. Thx!
Expansion Chasis for HD5 jerrahi Pro Tools TDM Systems (Mac) 1 08-12-2002 06:33 AM
expansion chasis robby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-19-2002 07:22 PM
Expansion Chasis/ 32 bit or 64 bit? blairl Pro Tools TDM Systems (Mac) 4 03-01-2002 07:02 AM
Expansion Chasis ratz Tips & Tricks 3 03-27-2001 05:29 AM
expansion chasis loutunes Pro Tools TDM Systems (Mac) 6 01-05-2000 04:59 PM
