Focusrite 420 or Avalon 737sp????
Please help. i'm using the focusrite 430 producer pack bu i have treid everything to get the sound i want from it but fail. I have recored in other studios the have used the Avalon 737sp and i have loved the sound they got from it. Are they at all similer or should i get the Avalon? By the way
what i mean is i'm tryin to get the vocals to sit up front in the mix that has warmth but does'nt lack clarity. I had the sound i wanted once but i don't think my focusrite is working properly. The last thing i tried to do was to record the vocal using the pre- amp but no EQ and then later patch the focusrite back in on the mix to EQ after witch did sound good but here's the thing.The digital SPDIFF signal that i connect the focusrite into pro-tools with seems to be weak beacuse with guitars and bass it's ok but when i do vocals i need the to have the signal hit way into the red on the VU meter just to get enought signal to come into pro-tools with without clipping,(I have turned up the output control )but it just isn't loud enough even with the fader all the way up. I have also tried the normal OP1 OUTPUT witch is way strange because it's way too loud. I need to turn the levels all the way down just under 1 too stop it from clipping. Wierd. Do you think theres a problem? |
Re: Focusrite 420 or Avalon 737sp????
We have had nothing but good results from this unit using the analogue out. I did get the digital card but returned it because it didn't work properly. It prevents the compression listening mode from functioning and I seem to remember a problem with sample rates too. I discussed it with focusrite who accepted the issue. I dont know what has happened since. I love it just the way it is though.
J |
avalon 737sp | x9blade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-31-2005 06:50 AM |
AVALON VT-737SP | Riad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-27-2004 10:45 AM |
Focusrite 430 or Avalon 737sp???? | june bug | Tips & Tricks | 2 | 10-19-2002 01:36 AM |
What Mic goes best with Avalon 737SP | Dal Hic | Tips & Tricks | 15 | 03-01-2002 12:57 AM |
AVALON 737SP | RIO B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 04-10-2000 10:59 AM |
