Old 01-08-2024, 07:10 AM
Armando Armando is offline
Default Patching iPhone(Apple Music/iTunes)
Hello! I’d like to know if it’s possible to patch an iPhone into the Control 24 for monitoring music when in a PT session and also when not. I know there are connections on the rear for External Sources In and Submix In but not sure they can be used/monitored when a session is open.
Looking forward to your suggestions!
Armando
Old 01-08-2024, 08:22 AM
tope d's Avatar
tope d tope d is offline
Default Re: Patching iPhone(Apple Music/iTunes)
Hi Armando!
This thread might help. https://duc.avid.com/showthread.php?t=412200
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 01-08-2024, 08:31 AM
its2loud its2loud is offline
It’s a little unclear what you’re asking but a simple google search would find you the manual
http://akarchive.digidesign.com/supp...ide.pdf#page23
In which case you would find that the Control 24 has a dedicated monitor section which allows for external sources which can be selected with or without an open session. If you’re looking for it to route your iPhone into Pro Tools then you would need to plug the iPhone into a dedicated input. But there are other ways to do this without cables.
Old 01-08-2024, 09:17 AM
Thanks! I was unaware this “multi mode” was available in the Utilities menu.
Armando
Using iphone music (itunes) as source for recording an audio track in pro tools dsarkisianyp Pro Tools 12 0 10-18-2015 12:35 AM
