Old 11-08-2022, 09:02 AM
ymerick ymerick is offline
Default D-Command connection with extension
Hello, I just bought a D-Command with an extension of 16 Faders. I did not have the ethernet cables and would like to know which cables to use please knowing that the two units will be plugged into a HUB where they will be alone and the hub will be plugged into my MAC PRO. I have conflicting info between crossover cables and straight cables. The cables, in my case, must be all straight, all crossed or both, and in this case how is the distribution done? Thank you for your help
Old 11-20-2022, 01:01 PM
Default Re: D-Command connection with extension
Use a network switch and all standard Cat5e(no crossover cables). You should also download the manual in PDF form as this info is in there, along with a hundred other things you will want to know.
Old 11-20-2022, 01:26 PM
Thanks a lot for your reply.🤗
Old 11-29-2022, 01:41 PM
AFAIK, crossover cables are only for very limited use between 2 boxes without a network switch. There are also some circumstances where a crossover cable can damage things(why the only crossover cable in my cable drawer has big X's on each end)
Old 11-29-2022, 09:55 PM
H i everybofy, thanks you for your replies.
I have solved m'y problem.
Regards
WTB: D-Command ES Fader extension Ru_C Buy & Sell 6 10-03-2020 03:00 AM
Icon D Command Blue with ES Fader Extension fugltind ICON & C|24 1 11-27-2019 02:48 AM
96I/O, XMON, D-command connection sjtae Pro Tools TDM Systems (Win) 12 04-23-2017 10:06 PM
D-Command/XMON connection to interface DaleB ICON & C|24 2 04-17-2011 11:20 AM
Midi connection causing stop command unresponsive losrack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-28-2010 02:12 AM
