Old 12-12-2015, 12:30 PM
Rectifried Rectifried is offline
Default NI Komplete Kontrol hosts VST AU in AAX
FYI Found this by accident. using the new NI KKontrol plugin.. I can host my VST AU plugs..
by pulling down the arrow next to the magnifier icon > plugins
and voila there they are
I was using DDMF
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
Old 12-15-2015, 05:24 AM
dtmprod dtmprod is offline
Default Re: NI Komplete Kontrol hosts VST AU in AAX
I'm guessing it must be a 64 bit only plugin. I'm still on PT 10 & it's not showing up in my plugin menu. Guess I'll stick with Blue Cat.....
Old 01-21-2016, 01:28 PM
dwaynedelario dwaynedelario is offline
How are you liking Kontrol in Pro Tools? I need a new keyboard. The only major bummer, from what I can tell by reading info on their website, is that track switching isn't available in PT. You have to select a VI track, arm it, and then hit the Instance button on the keyboard and select that VI in order for it to populate the controls. If this is true, that really blows.
MacOS 12.4 / Pro Tools Ultimate 2022.4
HTML code is On
Komplete Kontrol s61 controller not playing midi in PT 12 teslacoilal Virtual Instruments 6 04-27-2016 06:50 PM
Komplete Kontrol S61 KaneStarkey Pro Tools 12 0 11-09-2015 04:14 AM
Pro Tools 12 with NI Komplete Kontrol randb1 AAX Plug-ins 7 05-27-2015 02:20 PM
PT and Komplete Kontrol LAMEREALM Virtual Instruments 25 05-26-2015 04:58 AM
Loading Komplete Kontrol in Pro Tools 11 LadyKane Virtual Instruments 12 05-22-2015 04:53 PM
