Old 04-10-2013, 12:59 AM
Fooks Fooks is offline
Default PT11 and PT11 HD differences
I watched the Q&A, I am not a hater by any means and I think the upgrade pricing is fine. They put some info on the site about PT11 (not a lot, but some) there is the air user blog pod cast, and like I said...the podcast, they all answer the same questions. 64 bit, redesigned audio engine, pricing, no more CPTK, metering, dynamic metering, track freeze, speed bouncing...all great features.
Now when they talk about differences between versions (native vs HD) they only mention the customizable metering and disc cache only available in HD, well....? What other differences? What are the track count differences? Does HD have 16 trillion tracks available, and the native have 20? Does native have any kind of surround capabilities? Maybe 5.1 in native and up to 7.1 in HD. How many video tracks in native, etc. Not things that will make me want to leave the pro tools platform by any means, but just things that would be nice to know is all.
That is bunches of crunch!
Old 04-10-2013, 01:01 AM
Emcha_audio's Avatar
Default Re: PT11 and PT11 HD differences
A comparison chart should be in the works. Stay tuned.
Manny.
Wave-T.com
Old 04-10-2013, 07:45 AM
nst7 nst7 is offline
From what has been said and shown, the feature differences will be virtually identical to PT10.
You can look at the existing comparison chart and it will probably be identical:
http://www.avid.com/US/products/Pro-...atures#Compare
With the new PT11 features, it's already been established that regular and HD will get the improved metering, but only HD gets the 17 different metering types, and the gain reduction metering.
Extended Disk Cache remains HD only, just like in PT10.
The built in Satellite Link and Video Satellite LE functions remain HD only, because they actually require HD hardware to work (just like before).
So the main differences are surround mixing (HD only), higher track count (HD 256 mono, regular Protools 96 mono or stereo), input monitoring, and some automation features.
Old 04-10-2013, 08:39 AM
propower propower is offline
I wonder if 64bit and the improved AAE are enough to offset the current Disc Cache? The cache was one of the main reasons I stuck with HD10 instead of non-HD. With 64bit - shouldn't sessions just load to RAM??
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 04-10-2013, 12:20 PM
nigelpry's Avatar
nigelpry nigelpry is offline
nst7, thanks for the timely reminder about the PT10 comparison chart, i'd forgotten about that.
Wow, when you read through that, the list of things that will be lost in PT11 if we don't go the CPTK upgrade path is even more scary ;-(
PT11 to PT11 HD Native upgrade without hardware? kirkbross Pro Tools 11 2 11-04-2013 03:10 PM
PT LE 8.0.5 with PT11 plin Pro Tools 11 1 10-10-2013 08:23 AM
PT11 Only 870 meg!!? ArKay99 Pro Tools 11 2 08-30-2013 01:50 PM
PT11 isn't seeing my 002 jjtarnow Pro Tools 11 3 08-20-2013 10:10 AM
Will HDX not compatible with PT11? or not the best for Pt11? Rockman413 Pro Tools TDM Systems (Mac) 5 10-26-2011 10:00 PM
