Need help...songs key is now 1/2 step sharper
Yes, it is a song in D, or was a song in D. Sample rate and bit depth is the same. Quite honestly all that changed is I opened the project the next day and it is sharp, a half step sharp. No additional plugs, no elastique...nothing that I can tell. I tried shutting Pro Tools down, I did a computer restart...,nothing gets it back to D.
This song is now about 17 tracks...can't stand the thought of starting over. Any help would sure be appreciated. Pro Tools 9.03 Windows 7 Home Premium i7 Quad Core 2.83GHz 8 gigs ram M Audio Pro Fire 610 Thanks!
Sam |
Re: Need help...songs key is now 1/2 step sharper
How is your system clocked? Is there anything different between the 2 days regarding hardware? Sounds like you recorded at 44.1K, but now its playing back at 48K.
This is the telltale sign of a mis-clocked session. Generally, what happens is a session is created at one sample-rate. The users sets PT to receive clock from some external device that is sending audio to PT digitally, but the external device's sample rate is set to something different than the SR chosen for the session. Unfortunately, at the time you may not notice the problem, as everything will sound "okay". It is only when the external clock is removed or finally set correctly that the problem becomes apparent. There are ways that you can "re-sample" the audio files, and I'm sure they have been described on this forum many times.
Chris Neal :: South Plains College .: Program Coordinator & Asst. Professor in Sound Technology .: [email protected] .: Pro Tools Certified Instructor .: Pro Tools Expert Certified in Music |
That is the first thing I thought, too! But it is still 44 and nothing has changed that I am aware of. I have checked and checked....still stumped.
Sam |
But if this did happen could I just reset both to 48 and see if that corrects it? Or, do you have another suggestion? Thanks.
Sam |
If the ProFire was your interface, then it is probably not the source of the problem. Were you using any external mic pres or bringing in any audio via the S/PDIF connection, or had anything connected to it? Did you have your system clocking set to Internal (in the Hardware Setup)?
Can you detail exactly what you were using for recording? It is possible that there is some other reason, but with what little info you have given it is hard to say.
Nothing external at all. I am doing a very simple personal song/project. There is drums from a rendered software program (same bit and sample rate as project).....then 8 rhythm guitars, 2 melody gtrs, 2 harmony gtrs and 1 bass all plugged into the Pro Fire one track at a time. I have opened and added to the project over four or five separate days. Last night the key had changed from D to D#...almost, not quite all the way to D#. System set to internal clocking. What could I be missing?
Sam |
Just fired up Pro Tools and the Pro Fire and I am back to the key of D. Man, this makes no sense but it is good...I was ready for a miserable hour or two fixing this somehow.
It would be nice to know why this happened!
Sam |
How do I Step record my songs on ProTools? | Erikmusicman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-15-2017 02:55 AM |
Quantizing Live drums in 7.4. A Step by Step guide. | Ru_C | Pro Tools TDM Systems (Mac) | 19 | 07-29-2011 07:28 AM |
Needing Step by Step Videos - (read more for details). | Wavelabs | Pro Tools M-Powered (Win) | 2 | 04-16-2009 06:53 AM |
Alesis SR16 control of PTLE6 Step-by-step Needed | Violet Sun Electric | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-24-2003 02:14 AM |
How to Make an OS 9, Universal installer disc, from a G4, OS 9 CD; Step by Step! | editor | General Discussion | 2 | 04-21-2001 03:55 AM |
