Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 12-16-2010, 01:50 PM
Julia B Julia B is offline
Default Addictive Drums
For those of you who do not know, AD came out with an update to the Adrenaline Pack (now standard) that is free for registered owners. They are at 1.5.2. Just a heads up. I just found out about this and did the update. The plugin does load a bit quicker.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
Addictive Drums RTAS instrument plugin much softer when drums are "individualized" jglunt2112 RTAS & TDM Plug-ins 7 12-05-2013 06:54 PM
Addictive Drums PhilBuckle Pro Tools TDM Systems (Mac) 11 02-05-2012 08:46 PM
Addictive Drums paradiddlebob Pro Tools SE and Essential (Mac) 3 02-03-2012 08:58 PM
addictive drums, drums replacement ericlees Tips & Tricks 2 09-28-2010 10:58 PM
Addictive Drums Stickman7 The Drum Room 1 10-11-2009 07:15 PM
