Word Clock Problems......!!!
In a Setup consisting of a 1622 a MTP AV w/ super clock and a dbx 386 pre with S/PDIF outs im finding im having problems syncing. normally i run the super clock out to my 1622 in since i have an adat hooked up to my MTP AV but i cant chain the pre because of the 256x out of the super clock....then when i need to run the pre I send S/PDIF to the 1622 and stop slaving it to the superclock.... but 3 out of 5 times when im done with the pre and try to slave the 1622 to the MTP AV the 1622 freaks out and i need to restart my system. Also it cant be good switching the clocking sources around all the time. Theres got to be a more efficent way of doing this.
[img]images/icons/confused.gif[/img] |
Re: Word Clock Problems......!!!
If the MTP AV can output Word Clock and SuperClock simultaneously, then you can resolve the 386 to Word Clock. When you are ready to transfer from the 386 into Pro Tools, choose "S/PDIF" from the Ch1/2 Input menu (Setups>Hardware)...but leave the Sync Mode set to "Internal."
Brent |
Thank you that will help me when im recording from the 386 but the MTP can only transmit one clock sourse at a time.....should i get an external device that transmits both simultaneuosly? running a Pro Tools 24 system wit 1 dsp farm and samplcell TDM
Brent |
Word Clock Problems | skuz99b3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-19-2010 06:14 PM |
003 / Lucid 88192 / Word Clock Problems | geelo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 12-23-2009 11:06 AM |
Venue + ProTools + External Word Clock Problems | Travis Brockway | VENUE Live Sound Systems | 5 | 03-22-2008 11:03 AM |
ADAT WORD CLOCK PROBLEMS WITH DIGI 002 | circus14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-14-2005 10:56 AM |
Please Help!!! Word CLock problems | Musix | Pro Tools TDM Systems (Mac) | 7 | 11-29-2001 04:07 AM |
