Word Clock Problems
I've recently upgraded my system to Windows 7 ultimate 64 bit. After reinstalling Pro Tools to version 8.03 and also installing the new audio drivers (8.04 found in the sticky links at the top), I cannot record, playback anything at all. As soon as I hit the play button I get an error message saying that there is a problem with my word clock. Has anyone else run into this error? If so, what can I do to fix it? Also, when I load Pro Tools, when it gets to the part where its configuring the MIDI, my 003 Rack restarts itself.... Not sure at all why.
Re: Word Clock Problems
Welcome to the DUC...
Start here: http://duc.digidesign.com/showthread.php?t=193637 Then go here: http://duc.digidesign.com/showthread.php?t=133039 Once all of that is done, folks might be able to help you... we need the info. All that being said, Windows 7 is NOT supported. 64 bit anything is NOT supported. 8.0.3 should only be used as BETA until they get it all sorted out.. a few folks have working systems, but not as many as don't have with Win7 64 I can tell you now that one place you are going to have problems with the word clock errors is in your RAM timings.. Check for MANUFACTURER specifications and manually set your BIOS to match that. Good luck!
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Do you have any other device attached to the 003 via digital? If so, disconnect it and work on getting the basic system to run before adding extras. Also try trashing prefs and database files as described in the general troubleshooting link.
I had to play a lot with RAM timings after replacing ALL of my RAM on an otherwise stable system to get 8.0.3 to play nice. Any mixed source RAM should be avoided.
Ok, first off I thought I had filled out the signature thing here so all of my specs were posted - guess not. I am running an Intel E8400, forget the board I am currently using, 4 gigs of DDR2 800mhz. As I said I have the 003 Rack, and the only other device hooked into it is a PreSonus Studio Channel. I went through, downloaded the updates, and the device patch (beta) for 64 bit systems. After following the directions on Digi's page, I restarted and thought the problem was fixed. It wasn't, but when I went into the Device Manager, I found the old drivers didn't uninstall correctly and were still registered. I went through the steps to manually specify the drivers, to the beta patch, and like magic the problem is solved.
Thanks for the advice and suggestions! |
Good.
And yea, those original drivers are a bit sticky.
003 / Lucid 88192 / Word Clock Problems | geelo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 12-23-2009 11:06 AM |
Venue + ProTools + External Word Clock Problems | Travis Brockway | VENUE Live Sound Systems | 5 | 03-22-2008 11:03 AM |
ADAT WORD CLOCK PROBLEMS WITH DIGI 002 | circus14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-14-2005 10:56 AM |
Word Clock Problems......!!! | artworkjamal | Pro Tools TDM Systems (Mac) | 3 | 09-05-2002 07:51 AM |
Please Help!!! Word CLock problems | Musix | Pro Tools TDM Systems (Mac) | 7 | 11-29-2001 04:07 AM |
