96k 192k Digital Noise Problem?
I'm running HD3 Accel on a PC. I have a Sync I/O as the external clock and a 192 I/O interface.
I've noticed something when I record 96k or 192k. If I zoom all the way up on the waveform level and the zoom in on the frequency there are little "ticks" recorded, first they show as clusters, then if you zoom wider they are single pulses. I've recorded with nothing feeding my 192 and they are still there. I ran the same test at 48k and there is nothing there. A friend runs HD3 Accel on a Mac with a Big Ben clock. He has the same thing. He also did his first 96k session and on two of the tracks the ticks are audible. He gave me a copy of the session and on one of the tracks it sounds like a dial-up modem and you can see a bit stream. Any thoughts, please. |
Re: 96k 192k Digital Noise Problem?
Could it be a bad wordclock cable or a loose connection? Is there anything nearby that might be generating some kind of RF interference?
Should one terminate the wordclock at the last I/O? Both installations have long (12') digilink cables, can they be an issue? |
Something isn't adding up here.
If you have a Sync IO and a 192, there should be no need for word clock unless you're clocking to a source other than the Sync IO. Is that possibly the case? Clocking to a Sync IO is done through the loop sync connections. Your friend with the Big Ben obviously would be clocked to an external device. In your situation, though, without an external WC source maybe you're setting things up improperly, causing the problem. If you take the Sync IO out of the equation, does the problem go away? What about your friend - does the problem disappear if he clocks internally, rather than to the Big Ben? |
Will run "Tech Support Utility" on my clients machine. Wonder if others have a similar problem and don't know it. Is there another test other then recording a track and looking at it. BTW I have a Logitek UV-5.1 digital meter and the problem read on it very loud and clear but did not read on my 7.4 software, c24, or 192 meters or the UV-5.1 in analog mode. |
Structure Full - Digital click noise problem | anthoven | Virtual Instruments | 0 | 04-17-2011 03:16 PM |
Digital Noise Problem | Brian E Coombes | Pro Tools TDM Systems (Mac) | 1 | 01-24-2007 03:46 PM |
Severe digital noise problem - please help | DiscoD | Pro Tools TDM Systems (Mac) | 3 | 08-01-2005 08:15 PM |
Digital noise from PT | Voxer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-19-2005 01:33 PM |
ADA8000 to Digi001 - digital noise problem | uprightjazz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-30-2005 06:38 PM |
