Old 04-30-2008, 08:10 AM
legasafe legasafe is offline
Default ICON Faders - People\'s experience please
I read today the third complaint I have heard about fighting faders on both the D-Command and D-Control.
I am wondering how widespread this issue is?
Is it a general problem people are trying to get over? Or is it just specific to some of the desks? If I could get some feedback from different ICON users, particularly D-Control users that would be great.
How do you find the faders?
Thanks guys,
Elliott.
Old 04-30-2008, 10:49 AM
Drew Mazurek's Avatar
Default Re: ICON Faders - People\'s experience please
Once in a while, if I don't grab the fader properly (on top) it will fight a little, otherwise, mine are fine. This happens once or twice a week and seems mostly like user error.
I just had a Venue demo and the faders seem to be identical to my D Command.
www.drewmazurek.com
Old 04-30-2008, 04:34 PM
Branko's Avatar
Branko Branko is offline
It is a rare situation where I have to fight the fader on Icon. I spent the last week mixing on DFC - the feeling is the same. Occasionally, one has to insist a bit more to get the fader into Write mode on both consoles.
Branko
Branko Neskov c.a.s.
www.loudness-films.pt
Old 05-01-2008, 05:50 AM
mtung mtung is offline
I have two D-commands and both units have had to replace faders that simply would not behave. Since their replacement, they have all been working normal. However, once and a while a fader will not respond to anything. For example, if I move a bank of faders, there sometimes is a fader that doesn't snap to where it is supposed to. This same fader is fixed by calibrating the faders from the utilities page. Today they are all good, knock on wood.
mike
Old 05-01-2008, 07:31 AM
teacherman teacherman is offline
All three of my Digi control surfaces (D-Command, D-Control and ProControl) have daily (or hourly) encounters with Fighting Faders. Problem keeps occuring even when I have to often replace faders.
I was told by DigiSupport that the only Temp Fix for this is to Lick Your Fingers (keep fingers moist) before touching the faders. Although this seems to work, it is a gross and unsanitary. I guess you could keep a small cup of water to dip your fingers in before touching fader, but then would probably get water dripping into the unit and shorting out something in the console.
This is NOT how one is suppose to spend time mixing.
On other hand....I LOVE the feel of the fades on the VENUE...Very nice, Excellent!! No problems what so ever....EVER.
Why can't ICON's get the same faders as the Venue??
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo;
Old 05-01-2008, 07:43 AM
Are all three of your control surfaces under the same roof? Did you do the Venue session in the same place? Why is not everyone having the same issues as you?
www.drewmazurek.com
Old 05-01-2008, 01:42 PM
SBP SBP is offline
Sorry to hear of your problems. Just to let you know that the faders are good on the icon (D-control) here -we've never had to lick our fingers!
The pro control fights a bit sometimes -but its always done this.
I've found with the icon that you can be surprisingly light with the touch and get control.
Hope you get it sorted.
Cheers
Bruno
Old 05-01-2008, 02:38 PM
Stompinmsc Stompinmsc is offline
Ok, this might sound obsurd but I upgraded my Fader caps with SSL Duality Caps and I have never had a fight since. I have a 24 channel D-Command and the faders have been performing well. The SSL Caps are a hair wider too and seem to be heavier (in grams of course) They feel very good as well. The sides of the caps are dedented instead of raised and for me a bit easier to see the set value at a glance. Call me crazy...
Old 05-01-2008, 05:21 PM
Hey dmazurek,
No, I don't own a Venue. I've been doing some side work for a facility here in town that has a Venue.
L8TR,
Old 05-01-2008, 06:08 PM
I'd wonder why the 3 units at your place have issues and the unit that's not doesn't. Seems like a trend to me. I believe the faders are the same in Venues and ICONs.
And the Duality faders blow!!!! Same ones that are on a DM2000. We have all sorts of issues with them. For $300k I expected the Axiom faders which are great.
www.drewmazurek.com
FS: Blue Icon D Control 16 Faders, Surround panner, monitor arm, scribble tray, Xmon drogan88 Buy & Sell 0 01-16-2014 09:24 AM
Icon D-control faders - resistance in moving tvjorg ICON & C|24 5 07-19-2011 10:30 AM
Icon Faders Stuck on Aux sends with Pro Tools 9 acacia ICON & C|24 2 11-29-2010 07:00 AM
IF ICON BASE UNIT WAS 24 FADERS Hostage ICON & C|24 10 06-11-2004 10:50 AM
Solution to missing faders after changing session icon name...last try... Bastiaan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 06-16-2002 04:01 PM
