How do you program Motif synth data as audio?
I am currently programming sounds using a Motif ES8 into Pro Tools 7.3 via MBox. I am recording the sounds as MIDI tracks, and can see the data in the session. However, it will not play back, and is not included as audio in any of my bounces.
I have been told that (naturally) I need to record this sound into an audio track. OR convert the MIDI track into an audio track. How do I do this so that the data from my Motif shows up in my Pro Tools session? Thanks so much, in advance, for your help! G |
Re: How do you program Motif synth data as audio?
Principally, MIDI (Musical Instrument Digital Interface) is a specification for a communications protocol and as such does not contain sound. In order for Pro Tools to record Audio in this situation is to route a one quarter inch TRS or TS cable (mono or stereo) to the Audio Output source of the Motif to either the 'Line Level' or DI ('inst' on the Mbox) Input source on your Digi hardware. This same connection needs to be mirrored in the AUX Input selector in Pro Tools.
Check MIDI Thru and turn Local Off. Hope this helps. filosofem
Aaron Mulqueen - 001 HD Native |
syncing motif synth to macbook pro/pt | xelsior | Pro Tools 9 | 3 | 11-18-2011 01:38 PM |
Recording MIDI data into Audio (external synth) | typhy | macOS | 1 | 11-04-2011 06:49 AM |
Can I trigger a MOTIF synth from a MOTIF synth? | micline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-07-2010 03:56 PM |
Synth Guy or Motif users | stut5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-18-2002 05:59 AM |
yamaha Motif synth /ws | stut5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 06-10-2002 05:43 PM |
