Old 03-17-2006, 02:09 AM
1427 1427 is offline
Default Command8 - USB
Hi !
I`d like to use my Command8 on a distance approximatly 10 meters from the HP XW 8200 computer. HOW? If the max distance for USB 1.1 is 8 meters and for USB 2.0 - 3 meters. What kind of USB protocol (1.1 or 2.0) Comman8 used ?
Old 03-17-2006, 09:24 AM
nikki-k nikki-k is offline
Default Re: Command8 - USB
Unsure of USB specs...
I would try this down a few spots in the Command8 section of these forums...
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
Old 03-26-2006, 12:27 AM
laki laki is offline
Geffen makes a USB extender box. But I would try a long USB extension cable first. The studio I am working at just uses thes and has no problem. The run is about 10 Meters.
Command8 -vs- MC Mix? bendybones ProControl, Control|24, Command|8 17 11-18-2011 05:22 AM
Can I use 003 together with Command8? nstu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-08-2011 01:09 PM
Command8 and TDM os9 stizz0 ProControl, Control|24, Command|8 1 06-28-2007 04:47 AM
Using AD´s & DA´s from command8 with 001? ikke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-22-2005 07:05 AM
Command8 v. 002 robsoule ProControl, Control|24, Command|8 5 11-08-2004 10:58 AM
