  #21
Old 10-06-2005, 09:18 PM
100grit 100grit is offline
Default Re: Are TDM Systems as Buggy as LE?
I run my wireless network card off. I can only run up to 5-6 plugins (certainly not DVerb the cpu hog) and then I get the H/W Buffer problems galore. Increase...decrease...increase....decrese....no recording....!!!
Here's the rest of my specs:
***** Start of Report *****
<<< General >>>
Name: SiSoftware Sandra Lite Unicode (Win32 x86)
Version: 2005.7.10.60
Copyright: Copyright © SiSoftware Ltd 1995-2005. All
Rights Reserved.
Registered Owner: ShakaBrah
Licence Status: Evaluation copy, strictly for personal/
educational use only. For business/commercial
use, it can be trialled for 21 days.
Licence Extra: You are on day %i of your evaluation period.
Please see the SiSoftware site (http://
www.sisoftware.net) for purchase details.
URL: http://www.sisoftware.net/sandra/
E-Mail: [email protected]
Done By: ShakaBrah
Host Name: ELEMENT
System ID: {B04022FC-3AE2-4fb2-BF54-631BEEE87D75}
Run ID: {4BAC01A6-B040-4d29-919B-D3E18D8B2F77}
Done On: Thursday, October 06, 2005
Done At: 3:58:53 PM
<<< Comments >>>
Comments: Rain Element Audio PC
<<< System Summary >>>
< System >
Host Name: ELEMENT
User: ShakaBrah
Domain: RAIN
< Processor >
Model: Intel(R) Pentium(R) 4 CPU 3.00GHz
Speed: 2.99GHz
Performance Rating: PR3981 (estimated)
Cores per Processor: 1 Unit(s)
Threads per Core: 2 Unit(s)
Internal Data Cache: 16kB Synchronous, Write-Thru, 8-way set, 64
byte line size, 2 threads sharing
L2 On-board Cache: 1MB ECC Synchronous, ATC, 8-way set, 64 byte
line size, 2 lines per sector, 2 threads
sharing
< Mainboard >
Bus(es): AGP PCI IMB USB FireWire/1394 i2c/SMBus
MP Support: 1 Processor(s)
MP APIC: Yes
System BIOS: Intel Corp. RL86510A.86A.0089.P21.0502132202
Mainboard: Intel Corporation D865PERL
Total Memory: 510MB DDR-SDRAM
< Chipset 1 >
Model: Intel Corporation 82865G/PE/P, 82848P DRAM
Controller / Host-Hub Interface
Front Side Bus Speed: 4x 200MHz (800MHz data rate)
Total Memory: 512MB DDR-SDRAM
Memory Bus Speed: 2x 200MHz (400MHz data rate)
< Video System >
Desktop Monitors/Panels: 2
Monitor/Panel: Plug and Play Monitor
Adapter: Matrox Millennium G550 - English
< Physical Storage Devices >
Removable Drive: Floppy disk drive
Hard Disk: ST3200822A (186GB)
CD-ROM/DVD: LITE-ON COMBO SOHC-5232K (CD 52X Rd, 52X Wr)
(DVD 7X Rd)
< Logical Storage Devices >
1.44MB 3.5" (A:): N/A
Hard Disk (C:): 177GB (137GB, 77% Free Space) (NTFS)
Os_backup (D:): 9.8GB (6.1GB, 63% Free Space) (FAT32)
CD-ROM/DVD (E:): N/A
< Peripherals >
Serial/Parallel Port(s): 1 COM / 1 LPT
USB Controller/Hub: Intel(R) 82801EB USB Universal Host
Controller - 24D2
Controller - 24D4
Controller - 24D7
USB Controller/Hub: Intel(R) 82801EB USB2 Enhanced Host
Controller - 24DD
Controller - 24DE
USB Controller/Hub: USB Root Hub
USB Controller/Hub: USB Composite Device
FireWire/1394 Controller/Hub: OHCI Compliant IEEE 1394 Host Controller
Keyboard: HID Keyboard Device
Mouse: Microsoft PS/2 Mouse
Human Interface: HID-compliant device
Human Interface: HID-compliant consumer control device
Human Interface: USB Human Interface Device
< MultiMedia Device(s) >
Device: SoundMAX Integrated Digital Audio
< Printers and Faxes >
Model: EPSON Stylus Photo 785EPX
< Power Management >
AC Line Status: On-Line
< Operating System(s) >
Windows System: Microsoft Windows XP/2002 Professional (Win32
x86) 5.01.2600 (Service Pack 2)
< Network Services >
Adapter: Linksys Wireless-G PCI Adapter with
SpeedBooster
< Performance Tips >
Tip 2546: Large memory modules should be ECC/Parity.
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
<<< Mainboard Information >>>
< Mainboard >
Manufacturer: Intel Corporation
MPS Version: 1.40
Model: D865PERL
Version: AAC27646-213
Serial Number: BTRL44827338
System BIOS: 63-0100-000001-00101111-021305-iSPGDL
< On-board Devices >
Intel GMCH AGP Graphics Contro:Video Adapter (Disabled)
Intel 82562 Ethernet Device: Ethernet Adapter (Enabled)
Intel ICH4 Audio Device: Sound Adapter (Enabled)
FireWire IEEE P1394 Controller:Other (Enabled)
< System Memory Controller >
Error Correction Capability: None
Number of Memory Slots: 4
Maximum Installable Memory: 4GB
CHANNEL A DIMM0 - J5G1: Empty
CHANNEL A DIMM1 - J5G2: Manufacturer2 PartNum2 SerNum2 AssetTagNum2
DIMM Synchronous DDR-SDRAM 256MB/64 @ 400Mt/s
CHANNEL B DIMM2 - J5H1: Empty
CHANNEL B DIMM3 - J5H2: Manufacturer4 PartNum4 SerNum4 AssetTagNum4
< Chipset 1 >
Maximum FSB Speed / Max Memory:4x 200MHz / 2x 200MHz
Width: 64-bit
HTT - Hyper-Threading Technolo:Yes
IO Queue Depth: 12 request(s)
< Chipset 1 Hub Interface >
Type: Hub-Interface
Version: 1.50
Number of Ports: 3
Width: 8-bit
Full Duplex: Yes
Multiplier: 2/1x
< Logical/Chipset 1 Memory Banks >
Bank 2: 512MB DDR-SDRAM 3.0-3-3-8 1CMD
Channels: 2
Multiplier: 1/1x
Width: 64-bit
Refresh Rate: 7.80µs
Performance Acceleration Techn:No
Power Save Mode: No
Fixed Hole Present: No
< APIC 1 >
Version: 2.00
Multiplier: 1/2x
Maximum Interrupts: 24
IRQ Handler Engaged: Yes
Enhanced Support: Yes
< Memory Module 1 >
Manufacturer: Wintec
Type: 256MB DDR-SDRAM
Technology: 8x(32Mx8)
Speed: PC3200U 3.0-3-3-8
Version: 1.0
Date of Manufacture: Saturday, December 25, 1999
Set Timing @ 200MHz: 3.0-3-3-8
Set Timing @ 167MHz: 2.5-3-3-7
Set Timing @ 133MHz: 2.0-2-2-5
< Memory Module 2 >
Version: 1.0
< Environment Monitor 1 >
Model: SMSC EMC6D100X SMB
Version: 0.05
Mainboard Specific Support: No
< Temperature Sensor(s) >
Board Temperature: 39.0°C / 102.2°F td
CPU Temperature: 60.0°C / 140.0°F td
Power / Aux Temperature: 44.0°C / 111.2°F td
< Cooling Device(s) >
Auto Fan Speed Control: Yes
Chassis Fan Speed: 1327rpm
< Voltage Sensor(s) >
CPU Voltage: 1.31V
Aux Voltage: 1.46V
+3.3V Voltage: 3.33V
+5V Voltage: 5.08V
+12V Voltage: 11.94V
< AGP Bus(es) on Hub 1 >
Version: 3.00
Speed: 4x
Multiplier: 1/2x
Fast-Writes Enabled: No
Fast-Writes Support: Yes
Isochronous Mode Enabled: No
Addressing Enabled: 32-bit
Aperture Size: 64MB
< PCI Bus(es) on Hub 1 >
Version: 2.20
Number of Bridges: 2
PCI Bus 0: PCI (1/1x PCIClk)
PCI Bus 2: PCI (1/1x PCIClk)
< LPC Hub Controller 1 >
Model: Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC
Interface Bridge
ACPI Power Management Enabled: Yes
Delayed Transaction Enabled: Yes
< LPC Hub Controller 2 >
SMBus Controller
< USB Controller 1 >
Model: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB
UHCI Controller #1
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
Supported Speed(s): Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled: No
< USB Controller 2 >
UHCI Controller #2
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 3 >
UHCI Controller #3
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 4 >
UHCI Controller #4
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 5 >
2.0 EHCI Controller
Version: 2.00
Specification: 1.00
Interface: EHCI
Channels: 8
Companion Controllers: 4
Supported Speed(s): Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support: 64-bit
< FireWire/1394 Controller 1 >
Model: Intel Corporation FW322/323 IEEE1394 OHCI
FireWire Controller
Version: 1.00
Interface: OHCI
Channels: 64
Speed: 400MHz
< System SMBus Controller 1 >
Model: Intel 801xx/63xx SMBus
Version: 0.02
Specification: 2.00
Advanced TCO Mode Enabled: No
Slave Device Enabled: Yes
PEC Support: No
Speed: 100kHz
< Expansion Slot(s) >
J5C1 (1h): AGP-4x 32-bit +3.3V Full-Length Used (Intel
Corporation 82865G/PE/P, 82848P PCI-to-AGP
Bridge)
J6B2 (2h): PCI 32-bit +3.3V PME i2c/SMBus Full-Length
Available
J6B1 (3h): PCI 32-bit +3.3V PME i2c/SMBus Full-Length
Used
J7B1 (4h): PCI 32-bit +3.3V PME i2c/SMBus Full-Length
Available
J8B2 (5h): PCI 32-bit +3.3V PME i2c/SMBus Full-Length
Available
J8B1 (6h): PCI 32-bit +3.3V PME i2c/SMBus Full-Length
Available
< Port Connector >
J1A1 - PS2Mouse: Mouse - None / PS/2
J1A1 - Keyboard: Keyboard - None / PS/2
J2A1 - COM 1: Serial Port 16550A - None / DB-9 pin female
J4A2 - LPT1: Parallel Port ECP/EPP - None / DB-25 pin male
JA5A1 - USB: USB - None / USB
J9E1 - FireWire: FireWire/1394 - None / None
J2A2 - USB: USB - None / USB
JA5A1 - RJ-45 Type: Network - None / RJ-45
J4A1 - Audio Mic In: Audio - None / Mini-jack
J4A1 - Audio Line In: Audio - None / Mini-jack
J4A1 - Audio Line Out: Audio - None / Mini-jack
J4B1 - +12V: None - None / None
J3J1 - FDD: None - Floppy Disk / None
J5J2 - PRI IDE: None - ATA / None
J5J1 - SEC IDE: None - ATA / None
J9B2 - CDIN: Audio - CD-ROM Sound Input / None
J9B1 - AUX IN: Audio - None / None
J8J1 - FRONT PANEL HDR: None - None / None
J1F2 - CPU FAN: None - None / None
J9H3 - FNT PNL: None - None / None
J6J2 - FRONT CHASSIS FAN: None - None / None
J5B1 - REAR CHASSIS FAN: None - None / None
J7H2 - BIOS CONFIG: None - None / None
J8A1 - FP AUDIO: None - Proprietary / None
J7F1 - FRONT PANEL USB: None - None / None
J2J1 - PS: None - None / None
J6J3 - CH INTR: None - None / None
J9D1 - FireWire: None - None / None
J9E1 - FireWire: None - None / None
J7H1 - SATA-0: None - None / None
J6H1 - SATA-1: None - None / None
Notice 224: SMBIOS/DMI information may be inaccurate.
Tip 2511: Some memory slots are free so the memory can
be easily upgraded.
tip.
<<< CPU & BIOS Information >>>
<< CPU 1 [Processor 0, Core 0, Thread 0] >>
< Processor >
Speed: 2.99GHz
Package: FC µPGA478
Rated Speed/FSB: 3000MHz / 4x 200MHz
Multiplier: 15/1x
Minimum/Maximum Multiplier: 1/1x / 15/1x
Generation: G8
Name: P4P-T/J (Prescott) Pentium 4E 90nm 2.8-3.8GHz
1.25-1.40V
Revision/Stepping: 4 / 1 (0)
Stepping Mask: E0
Microcode: MU0F4112
Core Voltage Rating: 1.400V
Maximum Physical / Virtual Add:36-bit / 32-bit
Native Page Size: 4kB
Part Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Serial Number: To Be Filled By O.E.M.
< Co-Processor (FPU) >
Type: Built-in
< Processor Cache(s) >
Internal Trace Cache: 12kB Synchronous, Write-Thru, 8-way set, 64
byte line size
sharing
L2 Cache Multiplier: 1/1x (2993MHz)
< Upgradeability >
Socket/Slot: J2E1
Upgrade Interface: Socket 478
Supported Speed(s): 3.06GHz+
Version: 0.05
< Power Rating(s) >
CPU Core Power: 75W (estimated)
CPU Cooling System Thermal Res:0.29°C/W (estimated)
< Sensors >
CPU Temperature: 61.0°C / 141.8°F td
CPU Voltage: 1.31V
< Features >
FPU - Co-Processor Built-in: Yes
VME - Virtual Mode Extensions: Yes
DE - Debugging Extension: Yes
PSE - Page Size Extension: Yes
TSC - Time Stamp Counter: Yes
MSR - Model Specific Registers:Yes
PAE - Physical Address Extensi:Yes
MCE - Machine Check Exception: Yes
CX8 - Compare & Exchange 8-byt:Yes
APIC - Local APIC Built-in: Yes
SEP - Fast System Call: Yes
MTRR - Memory Type Range Regis:Yes
PGE - Page Global Enable: Yes
MCA - Machine Check Architectu:Yes
PAT - Page Attribute Table: Yes
PSE36 - 36-bit Page Size Exten:Yes
PSN - Unique Serial Number: No
CLF - Cache Line Flush Support:Yes
DS - Debug Trace & EMON Store: Yes
ACPI - Software Clock Control: Yes
(W)MMX Technology: Yes
FXSR - Fast Float Save & Resto:Yes
SSE Technology: Yes
SSE2 Technology: Yes
SS - Self Snoop: Yes
TM - Thermal Monitor: Yes
PBE - Pending Break Enable: Yes
IA64 Technology: No
SSE3 Technology: Yes
MON - Monitor/MWait: Yes
DSCPL - CPL qualified Debug St:Yes
VMX - Virtual Machine eXtensio:No
EST - Enhanced SpeedStep Techn:No
TM2 - Thermal Monitor 2: No
CID - Context ID: Yes
CX16 - Compare & Exchange 16-b:No
xTPR - Send Task Priority Mess:Yes
DAZ - Denormals Are Zero: Yes
< Advanced Settings >
Data Error Checking: No
Fast Strings: Yes
x86 FPU Compatibility Mode: No
Prefetch Queue: Yes
Branch Trace Storage: Yes
Data Cache Active Mode: Yes
Specific Platform Requirements:No
Control Temperature: 66.0°C / 150.8°F
< MP Settings >
Maximum Supported Configuratio:2-way
Bootstrap CPU: Yes
Global APIC Engaged: Yes
APIC ID: 0
APIC Cluster ID: 0
Arbitration ID: 0
< Machine Check Architecture Settings >
Number of Reporting Banks: 4 bank(s)
Extended Machine Check Support:Yes
Number of Extended Reporting B:12 bank(s)
< Variable Range MTRR Settings >
MTRR 0: 00000000-1FFFFFFF (0MB-512MB) WB
< Fixed Range MTRR Settings >
MTRR 0 Range 0: 00000000-0000FFFF (0kB-64kB) WB
MTRR 0 Range 1: 00010000-0001FFFF (64kB-128kB) WB
MTRR 0 Range 2: 00020000-0002FFFF (128kB-192kB) WB
MTRR 0 Range 3: 00030000-0003FFFF (192kB-256kB) WB
MTRR 0 Range 4: 00040000-0004FFFF (256kB-320kB) WB
MTRR 0 Range 5: 00050000-0005FFFF (320kB-384kB) WB
MTRR 0 Range 6: 00060000-0006FFFF (384kB-448kB) WB
MTRR 0 Range 7: 00070000-0007FFFF (448kB-512kB) WB
MTRR 1 Range 0: 00080000-00083FFF (512kB-528kB) WB
MTRR 1 Range 1: 00084000-00087FFF (528kB-544kB) WB
MTRR 1 Range 2: 00088000-0008BFFF (544kB-560kB) WB
MTRR 1 Range 3: 0008C000-0008FFFF (560kB-576kB) WB
MTRR 1 Range 4: 00090000-00093FFF (576kB-592kB) WB
MTRR 1 Range 5: 00094000-00097FFF (592kB-608kB) WB
MTRR 1 Range 6: 00098000-0009BFFF (608kB-624kB) WB
MTRR 1 Range 7: 0009C000-0009FFFF (624kB-640kB) WB
MTRR 2 Range 0: 000A0000-000A3FFF (640kB-656kB) UC
MTRR 2 Range 1: 000A4000-000A7FFF (656kB-672kB) UC
MTRR 2 Range 2: 000A8000-000ABFFF (672kB-688kB) UC
MTRR 2 Range 3: 000AC000-000AFFFF (688kB-704kB) UC
MTRR 2 Range 4: 000B0000-000B3FFF (704kB-720kB) UC
MTRR 2 Range 5: 000B4000-000B7FFF (720kB-736kB) UC
MTRR 2 Range 6: 000B8000-000BBFFF (736kB-752kB) UC
MTRR 2 Range 7: 000BC000-000BFFFF (752kB-768kB) UC
MTRR 3 Range 0: 000C0000-000C0FFF (768kB-772kB) UC
MTRR 3 Range 1: 000C1000-000C1FFF (772kB-776kB) UC
MTRR 3 Range 2: 000C2000-000C2FFF (776kB-780kB) UC
MTRR 3 Range 3: 000C3000-000C3FFF (780kB-784kB) UC
MTRR 3 Range 4: 000C4000-000C4FFF (784kB-788kB) UC
MTRR 3 Range 5: 000C5000-000C5FFF (788kB-792kB) UC
MTRR 3 Range 6: 000C6000-000C6FFF (792kB-796kB) UC
MTRR 3 Range 7: 000C7000-000C7FFF (796kB-800kB) UC
MTRR 4 Range 0: 000C8000-000C8FFF (800kB-804kB) UC
MTRR 4 Range 1: 000C9000-000C9FFF (804kB-808kB) UC
MTRR 4 Range 2: 000CA000-000CAFFF (808kB-812kB) UC
MTRR 4 Range 3: 000CB000-000CBFFF (812kB-816kB) UC
MTRR 4 Range 4: 000CC000-000CCFFF (816kB-820kB) UC
MTRR 4 Range 5: 000CD000-000CDFFF (820kB-824kB) UC
MTRR 4 Range 6: 000CE000-000CEFFF (824kB-828kB) UC
MTRR 4 Range 7: 000CF000-000CFFFF (828kB-832kB) UC
MTRR 5 Range 0: 000D0000-000D0FFF (832kB-836kB) UC
MTRR 5 Range 1: 000D1000-000D1FFF (836kB-840kB) UC
MTRR 5 Range 2: 000D2000-000D2FFF (840kB-844kB) UC
MTRR 5 Range 3: 000D3000-000D3FFF (844kB-848kB) UC
MTRR 5 Range 4: 000D4000-000D4FFF (848kB-852kB) UC
MTRR 5 Range 5: 000D5000-000D5FFF (852kB-856kB) UC
MTRR 5 Range 6: 000D6000-000D6FFF (856kB-860kB) UC
MTRR 5 Range 7: 000D7000-000D7FFF (860kB-864kB) UC
MTRR 6 Range 0: 000D8000-000D8FFF (864kB-868kB) UC
MTRR 6 Range 1: 000D9000-000D9FFF (868kB-872kB) UC
MTRR 6 Range 2: 000DA000-000DAFFF (872kB-876kB) UC
MTRR 6 Range 3: 000DB000-000DBFFF (876kB-880kB) UC
MTRR 6 Range 4: 000DC000-000DCFFF (880kB-884kB) UC
MTRR 6 Range 5: 000DD000-000DDFFF (884kB-888kB) UC
MTRR 6 Range 6: 000DE000-000DEFFF (888kB-892kB) UC
MTRR 6 Range 7: 000DF000-000DFFFF (892kB-896kB) UC
MTRR 7 Range 0: 000E0000-000E0FFF (896kB-900kB) UC
MTRR 7 Range 1: 000E1000-000E1FFF (900kB-904kB) UC
MTRR 7 Range 2: 000E2000-000E2FFF (904kB-908kB) UC
MTRR 7 Range 3: 000E3000-000E3FFF (908kB-912kB) UC
MTRR 7 Range 4: 000E4000-000E4FFF (912kB-916kB) UC
MTRR 7 Range 5: 000E5000-000E5FFF (916kB-920kB) UC
MTRR 7 Range 6: 000E6000-000E6FFF (920kB-924kB) UC
MTRR 7 Range 7: 000E7000-000E7FFF (924kB-928kB) UC
MTRR 8 Range 0: 000E8000-000E8FFF (928kB-932kB) UC
MTRR 8 Range 1: 000E9000-000E9FFF (932kB-936kB) UC
MTRR 8 Range 2: 000EA000-000EAFFF (936kB-940kB) UC
MTRR 8 Range 3: 000EB000-000EBFFF (940kB-944kB) UC
MTRR 8 Range 4: 000EC000-000ECFFF (944kB-948kB) UC
MTRR 8 Range 5: 000ED000-000EDFFF (948kB-952kB) UC
MTRR 8 Range 6: 000EE000-000EEFFF (952kB-956kB) UC
MTRR 8 Range 7: 000EF000-000EFFFF (956kB-960kB) UC
MTRR 9 Range 0: 000F0000-000F0FFF (960kB-964kB) WP
MTRR 9 Range 1: 000F1000-000F1FFF (964kB-968kB) WP
MTRR 9 Range 2: 000F2000-000F2FFF (968kB-972kB) WP
MTRR 9 Range 3: 000F3000-000F3FFF (972kB-976kB) WP
MTRR 9 Range 4: 000F4000-000F4FFF (976kB-980kB) WP
MTRR 9 Range 5: 000F5000-000F5FFF (980kB-984kB) WP
MTRR 9 Range 6: 000F6000-000F6FFF (984kB-988kB) WP
MTRR 9 Range 7: 000F7000-000F7FFF (988kB-992kB) WP
MTRR 10 Range 0: 000F8000-000F8FFF (992kB-996kB) WP
MTRR 10 Range 1: 000F9000-000F9FFF (996kB-1000kB) WP
MTRR 10 Range 2: 000FA000-000FAFFF (1000kB-1004kB) WP
MTRR 10 Range 3: 000FB000-000FBFFF (1004kB-1008kB) WP
MTRR 10 Range 4: 000FC000-000FCFFF (1008kB-1012kB) WP
MTRR 10 Range 5: 000FD000-000FDFFF (1012kB-1016kB) WP
MTRR 10 Range 6: 000FE000-000FEFFF (1016kB-1020kB) WP
MTRR 10 Range 7: 000FF000-000FFFFF (1020kB-1024kB) WP
< PAT Settings >
PAT 0: WB
PAT 1: WC
PAT 2: UC-
PAT 3: UC
PAT 4: WB
PAT 5: WC
PAT 6: UC-
PAT 7: UC
tip.
<< CPU 2 [Processor 0, Core 0, Thread 1] >>
< Processor >
Speed: 2.99GHz
Package: FC µPGA478
Multiplier: 15/1x
Generation: G8
1.25-1.40V
Stepping Mask: E0
Microcode: MU0F4112
Type: Built-in
byte line size
sharing
< Upgradeability >
Socket/Slot: J2E1
Version: 0.05
< Power Rating(s) >
CPU Cooling System Thermal Res:0.31°C/W (estimated)
< Sensors >
CPU Temperature: 62.0°C / 143.6°F td
CPU Voltage: 1.31V
< Features >
SSE Technology: Yes
IA64 Technology: No
Fast Strings: Yes
Prefetch Queue: Yes
< MP Settings >
Bootstrap CPU: No
APIC ID: 1
APIC Cluster ID: 0
Arbitration ID: 0
< PAT Settings >
PAT 0: WB
PAT 1: WC
PAT 2: UC-
PAT 3: UC
PAT 4: WB
PAT 5: WC
PAT 6: UC-
PAT 7: UC
tip.
<< System BIOS >>
< General Information >
Manufacturer: Intel Corp.
Version: RL86510A.86A.0089.P21.0502132202
Date of Manufacture: Sunday, February 13, 2005
Plug & Play Version: 1.00
SMBIOS/DMI Version: 2.30
(EE)PROM Size: 512kB
< General Capabilities >
Can be Updated/Flashed: Yes
Can be Shadowed: Yes
Is Socketed: No
Supports Plug & Play: Yes
Supports ESCD: No
Supports Enhanced Disk Drive: Yes
NEC PC-98 Spec Compatible: No
< Power Management Features >
Supports APM: Yes
Supports ACPI: Yes
Supports Smart Battery: No
< Boot Features >
Supports Selective Booting: Yes
Supports CD/DVD Boot: Yes
Supports PCMCIA/CardBus Boot: No
Supports LS-120 Boot: Yes
Supports ZIP Boot: Yes
Supports i2o Boot: No
Supports FireWire/1394 Boot: No
Supports BIOS Boot Block: Yes
Supports Interactive Network B:Yes
Tip 212: BIOS can be shadowed so check whether it is.
Warning 214: BIOS is flash-able but surface-mounted. An
unsuccessful flash may be fatal.
tip.
<<< APM & ACPI Information >>>
< ACPI BIOS >
Version: 1.00
Manufacturer: ACPIAM
Revision: 2.13
MP APIC: Yes
SCI ACPI IRQ: 9
< Advanced Power Management Information >
Supported S(leep) States: S1, S4, S5
UPS: No
Thermal Zones: No
Power Button: Yes
Sleep Button: Yes
Lid Button: No
Display Dimming Supported: No
Hibernate Supported: No
< Wake Capabilities >
Timer Wake State: S4
< Drives Power Management >
Drives Spin Down Enabled: Yes
Drive Spin Range: 3 seconds(s) - 3600 seconds(s)
< Power Schemes >
Home/Office Desk: This scheme is suited to most home or desktop
computers that are left plugged in all the
time. (Active)
Portable/Laptop: This scheme is designed for extended battery
life for portable computers on the road.
Presentation: This scheme keeps the monitor on for doing
presentations.
Always On: This scheme keeps the computer running so
that it can be accessed from the network.
Use this scheme if you do not have network
wakeup hardware.
Minimal Power Management: This scheme keeps the computer on and
optimizes it for high performance.
Max Battery: This scheme is extremely aggressive for
saving power.
< APM System Status >
tip.
<<< PCI(e), AGP, CardBus Bus(es) Information >>>
<< Generic >>
<< Interface >>
< System Buses >
AGP Bus(es): 1
PCI Bus(es): 2
Interface Version: 2.20
< Interface Properties >
Config space access mechanism :Yes
Config space access mechanism :No
Cycle generation mechanism 1 s:No
Cycle generation mechanism 2 s:No
<< PCI Bus 0 (1/1x PCIClk) >>
<< Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface >>
< Device Information >
Device Type: Host Processor Bridge
Device ID: bus 0, device 0, function 0
OEM Device Name: Intel Corporation 82865G/PE/P, 82848P DRAM
OEM Hardware ID: FUN_0, VEN_8086, DEV_2570, REV_02
Product ID: VEN_8086, DEV_2570
Revision: A / 3 (2)
< Host Capabilities >
Version: 1.00
Mobile: No
< AGP Capabilities >
Version: 3.00
Command Queue Length: 32
Over 4GB Addressing Support: No
Isochronous Mode Support: No
Addressing Support: 32-bit
Data Transfer Modes Support: 1x 2x 4x
< Device Capabilities >
I/O port resources: No
Memory resources: Yes
Bus Master Capable: Yes
Special Cycle Recognition: No
Memory Write & Invalidate: No
VGA Palette Snoop: No
Parity Error Response: No
Address/Data Stepping: No
System Error Line: Yes
Fast back-to-back Transactions:No
Detects Parity Errors: No
Supports System Error Line: No
Supports Parity Line: No
User Defined Format: No
66MHz Bus Support: No
New Capability List: Yes
Device Select Timing: Fast
Multi-Function Device: No
Header: 00
Interface: 00
< Hardware Resources >
Memory Range: F8000000
Dynamic Management: Yes
<< Intel Corporation 82865G/PE/P, 82848P PCI-to-AGP Bridge >>
Device Type: PCI to PCI Bridge
Device ID: bus 0, device 1, function 0
Windows Device Name: Intel(R) 82865G/PE/P/GV/82848P Processor to
AGP Controller - 2571
OEM Device Name: Intel Corporation 82865G/PE/P, 82848P PCI-to-
AGP Bridge
OEM Hardware ID: FUN_0, VEN_8086, DEV_2571, REV_02
Revision: A / 3 (2)
Latency Timer: 32 clk
I/O port resources: Yes
66MHz Bus Support: Yes
New Capability List: No
Header: 01
Interface: 00
< Bridge Settings >
Primary Bus No.: 0
Secondary Bus No.: 1
Subordinate Bus No.: 1
Decoding: Positive
<< Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 >>
Device Type: Universal Serial Bus Controller
Device ID: bus 0, device 1D, function 0
Windows Device Name: Intel(R) 82801EB USB Universal Host
Controller - 24D2
OEM Device Name: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB
UHCI Controller #1
OEM Hardware ID: FUN_0, VEN_8086, DEV_24D2, REV_02
UHCI Controller #1
Product ID: VEN_8086, DEV_524C
Revision: A / 3 (2)
Memory resources: No
Device Select Timing: Medium
Multi-Function Device: Yes
Header: 00
Interface: 00
I/O Range: 0000CC00
Irq. No.: 16
INT Pin: A#
<< Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 >>
Device ID: bus 0, device 1D, function 1
Controller - 24D4
UHCI Controller #2
OEM Hardware ID: FUN_1, VEN_8086, DEV_24D4, REV_02
UHCI Controller #2
Revision: A / 3 (2)
Header: 00
Interface: 00
I/O Range: 0000D000
Irq. No.: 19
INT Pin: B#
<< Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 >>
Device ID: bus 0, device 1D, function 2
Controller - 24D7
UHCI Controller #3
OEM Hardware ID: FUN_2, VEN_8086, DEV_24D7, REV_02
UHCI Controller #3
Revision: A / 3 (2)
Header: 00
Interface: 00
I/O Range: 0000D400
Irq. No.: 18
INT Pin: C#
<< Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 >>
Device ID: bus 0, device 1D, function 3
Controller - 24DE
UHCI Controller #4
OEM Hardware ID: FUN_3, VEN_8086, DEV_24DE, REV_02
UHCI Controller #4
Revision: A / 3 (2)
Header: 00
Interface: 00
I/O Range: 0000D800
Irq. No.: 16
INT Pin: A#
<< Intel Corporation 82801EB/ER (ICH5/ICH5R) USB 2.0 EHCI Controller >>
Device ID: bus 0, device 1D, function 7
Windows Device Name: Intel(R) 82801EB USB2 Enhanced Host
Controller - 24DD
2.0 EHCI Controller
OEM Hardware ID: FUN_7, VEN_8086, DEV_24DD, REV_02
2.0 EHCI Controller
Revision: A / 3 (2)
Version: 2.00
Supports Clock Slow-down: No
Supports D1 PM State: No
Supports D2 PM State: No
Supports PME#: Yes
Supports PME Clock: No
  #22
Old 10-06-2005, 09:53 PM
nikki-k nikki-k is offline
(quote:)
hehehe- just kidding!
OK- you have Hyperthreading on?
If so (lloks like you do), try with it off.
Also, your CPU looks like it is running a bit warm...I know it is a Prescott, but still- good lawd!
Didnt have time to go thru the whole report yet, just skimmed the first half real quick.
Will try to find time to skim more later...
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
  #23
Old 10-07-2005, 06:14 AM
Thanks for the look. Yes, I've tried running PTLE without hyperthreading and no difference, same lags and error messages, only my cpu was suddenly cut by almost 30%. Thanks again.
  #24
Old 10-10-2005, 08:03 AM
s0nguy s0nguy is offline
A few things:
1. I didnt see (upon first glance) a secondary hard drive. You might have one on the FW buss....If not, get one. Dont track to system drive.. I assume you knew that.
2. RAM is a little light but not so light that you shouldnt be able to run 5-6 plugs.
3. CPU temp is up there... The P4 will scale itself back when it gets too hot...unlike the AMD64 which just shuts off. Try running PT with the side panel off and a fan blowing into the case.. .I know it sounds weird but heat can cause all kinds of random annoying things to happen...
If that aint it...we'll get ot it sooneror later.
-S0nguy
  #25
Old 10-11-2005, 12:52 AM
steve at Your Heaven steve at Your Heaven is offline
Are you also posting this in the LE forum?
Try these if you have not already done so:
In Network Connections, defintely disable the 1394 network connection (caused me problems with an LE setup). Try disabling all network connections. Disable the on board audio.
As some 1394 chipsets have caused problems with TDM setups, try disabling the 1394 ports. If reliant on a 1394 drive for recording, do a simple test recording (2-8 tracks) to the system drive. As a trial, it would make sense to disable all ports.
I don't know much about it, but the memory description seems odd, that slots A1 and B3 are used while A0 and B2 are empty (I'd expect to see, eg, A0 and A1 as a pair; but the nomenclature on your board may be different, etc.).
steve
Your Heaven
PT 11 Buggy for sure bonzerboy Pro Tools 11 1 01-02-2014 05:59 PM
buggy buggy buggy,,,, shutiri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-08-2007 10:08 PM
6.4 Buggy N-G-NEER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 32 05-06-2004 09:33 AM
Digi - What bits are cut off on the LE systems that aren't on the TDM systems? Calvin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-24-2003 08:49 PM
iTunes 4 and Mbox are still a bit buggy (or I'm I buggy) Pat Thrall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-24-2003 11:01 AM
