Old 02-08-2002, 06:26 PM
c-post c-post is offline
Default omf avid to pt: sync slippage
I'm working on 6, 15 minute reels generated from an AVID OMF and converted to PT via Digitranslator 2. The AVID OMF's were 24 fps and after loading into PT I changed them to 29.97 ND and with pulldown.
Then I digitize the 3/4 worktapes and bring 'em online.
The problem is that WITH pulldown, the online video drifts against the 3/4" tapes I'm chasing. Good thing I checked that.
If I remove pulldown from the session, the online picture locks up well with the 3/4 picture, but then the audio drifts.
The only solution I can come up with is to stretch the dialogue by inserting a frame into the dialogue every 20-30 seconds or so (to make the audio run longer). I think it's quite a bit more of a drift than a drop/non-drop discrepancy. This will do, but if anybody has a more cool suggestion, please make it.
-John
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!"
Old 02-10-2002, 11:26 PM
Paul Greyson Paul Greyson is offline
Default Re: omf avid to pt: sync slippage
You're working with QuickTime capture?
Paul Greyson
Digidesign Engineering
Old 02-10-2002, 11:56 PM
Well, yeah, I digitize the video in Premiere 6 at 700K/sec (360x240). Mac G4.
-John
Old 02-13-2002, 02:25 PM
The latest PT version, 5.1.3. 24 mix plus on a G4 "Dual" 500.
-John
Old 02-14-2002, 12:27 AM
Scott Wood Scott Wood is offline
What version on Pro Tools are you using?
There was a bug in Pro Tools versions 5.0 and earlier. When at 29.97 frame rate and the audio pull down was enabled, the Quicktime was pulled down also.
This should have been corrected in Pro Tools 5.0.1 or higher.
(Remember you do need to re-spot the Quicktime video after you change the frame rate or pull down settings.)
Scott Wood
Systems Integration Consulting
Digidesign
Old 02-16-2002, 10:21 AM
potatohead potatohead is offline
Sounds like you need that old Premiere 4.2 functionality called "conform movie to 30fps". Adobe removed this command from future versions, but I've been told they just changed the name. In 4.2 or 4.2LE, this command would take something like 10 seconds to process a 29.97 movie. Can anyone say exactly how you do this in Premiere 5.1, 6.0, etc.?
I'm absolutely sure this is why your captured video is not syncing correctly to the 29.97/pulldown session.
FYI, there is a utility available online called QT Mutator that may do the same thing, but I haven't had a chance to check it out.
Good luck.
Old 02-16-2002, 10:34 AM
Thanks for the knowledgeable response. That really helps out. Will look into it.
-John
HTML code is On
sync to Avid Scratch rafukyo Pro Tools TDM Systems (Mac) 1 02-11-2010 04:12 AM
MIDI Slippage in 7.2 HD when opening older files rtblackdog Pro Tools TDM Systems (Mac) 0 08-31-2006 08:41 AM
Marker slippage - moving markers bignick Tips & Tricks 5 07-04-2006 01:03 AM
AVID and PT sync question? Pentium Post - Surround - Video 10 04-06-2005 01:54 AM
AVID / PT sync - Help Iamrod Pro Tools TDM Systems (Mac) 3 05-17-2001 01:33 PM
