Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
  #21
Old 07-31-2018, 08:27 PM
Trak Trak is offline
Default Re: 2018.7 So Far...
Just played a bunch of 88.2 sessions with a 128 buffer that occasionally stopped with the buffer warning in 2018.4. No problems with 2018.7. It seems more efficient. I was watching the System Core Usage and it seems like the rise/falls on the cores are smoother and faster.
I shutdown feeling optimistic. I'll try recording at a low buffer to see how that goes.
MacPro 3.46 x 12 (2009) 48g, MacOS 10.12.6, PTHDN 2018.7, 2-Avid 16x16 I/Os, Flashed 7950 Video Card
  #22
Old 07-31-2018, 08:39 PM
xrekcor's Avatar
xrekcor xrekcor is offline
just finished installing PT2018.7 update on my Mac. when I open PT it throws up this error prompt
"Could not create a new document because Assertion in "/Volumes/Development/223020/ProTools/DFW/Views/UMenu.MacOS.mm", line 1813.
(Use the Copy button to copy this message to the clipboard.). "
then when you try yo open a session it throws up.....
"the current playback engine does not support a sample rate of 96kHz"
when you try to open "Setup>Playback Engine" it throws up....
"the current playback engine does not support a sample rate of 44.1kHz"
Pro Tools has become completely unusable
Rob
MBP 15” 2018 macOS Mojave 10.14.5 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2019.6-23.#, Cubase 9.5, Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
  #23
Old 07-31-2018, 09:19 PM
clutch clutch is offline
Looks like your OS isn't supported on the mac yet...
He used to cut the grass...he was a very nice boy...
  #24
Old 07-31-2018, 09:29 PM
jeffro's Avatar
jeffro jeffro is offline
"Could not create a new document because Assertion in "/Volumes/Development/223020/ProTools/DFW/Views/UMenu.MacOS.mm", line 1813...
Does launching with the N key down (to select the Playback Engine) help? Sounds like a mismatch with the Engine and hardware/driver. More info on OS and hardware/driver please?
  #25
Old 07-31-2018, 09:50 PM
xrekcor's Avatar
Yup thanks that fixed it. I actually had to reinstall the driver for my UR44 as the after the update to 2018.7 was perform the driver was gone from my machine. so I reinstalled and that when I got the issues I posted above about.
anyways holding "N" down while I launched PT fixed it. I closed down and shut down and restarted to test and all is still good.
thanks again.... thought I might have to uninstall and reinstall 2018.4
Rob
  #26
Old 07-31-2018, 09:53 PM
TNM TNM is offline
Originally Posted by SigFriedChicken View Post
Unfortunately, there is no supported way to install 10.13.3 since Apple no longer offers the base installation of 10.13. Unless you happened to already update to 10.13 prior to the release of 10.13.4, you're stuck. If you're lucky, you can stay on 10.12.x for a while.
It would be nice if there was more information from Avid regard what it is about the OS that is causing the performance issues. I realize that this may be a complex issue, but the reality is that both Apple and Microsoft are getting aggressive about inducing people to update to later versions at a faster pace. It's no longer realistic for a DAW vendor to simply throw their hands up and say that an OS revision is not supported nearly six months after its general release.
If anyone is interested, it took a lot of searching, but a kind soul at steinberg forums gave me 10.13.2 full installer. I had located one previously here, but the mac wouldn't open it as said it wasn't a signed file (naughty naughty uploader). This one is 100% legit and works.
I am happy to upload it to my dropbox for a while (just a free account) if anyone needs it, i have tested it, works perfectly, sierra recognizes is as the legit installer, no warning pop ups.
it will take me ages due to 2.5 mb/s upload so give me a day I guess.. if you really want it let me know and i'll start uploading now! This will work on any imac pro as imac pro's first came with 10.13.2 :) Then you would just need the 10.13.3 imac pro specific update and you'll have the best high sierra DAW experience possible.
1) iMac Pro 3.2ghz 8 Core, 64GB Ram, 2TB SSD, OS 10.13.6, Caldigit TS3+ Dock, Startech USB-C raid enclosure w/ Crucial MX500 1TB x2, 1TB SSD-R G Tech x 2, Samsung 860 Pro 512gb Audio Drive in USB C Enclosure, TBolt Apollo 8 x 2, TI2 Desktop, MoxF6, tons more midi synths, PT 2018.7/Cubase9.5.
2) MBP 2.8ghz i7 quad, 16GB ram, 1TB SSD, OS 10.12.6, PT 2018.7, Logic 10.4.1,Internal Sound, TBolt SSD 512GB.
  #27
Old 07-31-2018, 10:42 PM
zion's Avatar
zion zion is offline
Originally Posted by TOM@METRO View Post
So far... Error free and crash free here. (Windows 10)
Same Here! It's much more stable even at lower latency. Also the new features are a nice addition.
Pro Tools 2019.6 | Studio One 4.5 Pro | Pro Tools 12.5.2 HD | Apollo X8 | UAD Octo Sat | UAD Quad Sat | Mac Mini 2018 i7 | 16GB Ram | 512GB SSD | Mojave 10.14.3 | OWC ThunderBay 4 | Drives’s Samsung EVO 860 + 840 + Crucial M4 SSD | Plugins | UAD, Softube, Waves, Nugen, Fabfilter, SSL, Lexicon, Eastwest, NI KOMP 9 ULT, PSP, IKMulti, Antares, Celemony, Slate Dig, etc | AKAI Pro Adv 61 | PreSonus Fader Port | Townsend Labs Sphere L22
  #28
Old 07-31-2018, 11:28 PM
Becharax's Avatar
Becharax Becharax is offline
I am running still the 2018.4 on 10.13.3 Mac and Very stable ... I am gonna stick to it for now unless there is something drastic in this release that I don't see here .... I just hope they will support the latest 10.13 release so we can update
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
macOS 10.13.6
Pro Tools 2019.6
Logic Pro X
Reason 10.4
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack SPDIF/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad Thunderbolt
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Ibanez Pedals/Fender Strat/Acoustic Yamaha Guitar
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840
http://equipboard.com/becharasaliba
  #29
Old 07-31-2018, 11:32 PM
Drew Mazurek's Avatar
1. On the Mac, you can install as many versions of PT as you like by simply renaming the app before running the new installer.
2. Type Ahead for plugins and busses, etc alone is worth the update IMO.
www.drewmazurek.com
  #30
Old 08-01-2018, 12:47 AM
Becharax's Avatar
I didnt quite get the 1st part of your answer ... can you explain please ?
System Details:
macOS 10.13.6
Pro Tools 2019.6
Logic Pro X
Reason 10.4
MOOG Mother 32
Nektar Panorama P1
OS 10.13.5 - will PT 2018.4 or .5 work well or stay with 2018.13? blankpro Pro Tools 2018 4 07-11-2018 07:22 PM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 04:41 PM
Reverting from 2018.3 to 2018.1 jamesleonard Pro Tools 2018 11 03-12-2018 05:21 AM
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
