Old 10-14-1999, 04:15 PM
Guest
Posts: n/a
Default Pull out hot swap drives from PT 5 TDM, plug into PT 5 LE and continue?
Many people are interested in 001 & LE as a secondary system, could I (after some preperation) pull 2 hot swap 9 gig drives from a full TDM PT 5 session and attach them to a 001 system and continue with my session? (assuming I had switched off all TDM plugs and the sessions had less than 24 tracks)
And could I just swap the drives back to the TDM system as well?
Thank you, (cheque book at the ready!)
Jules
P.S. If not. please describe in detail the procedure to do what I just described above.
Old 10-14-1999, 04:30 PM
Digi Engineering Digi Engineering is offline
Default Re: Pull out hot swap drives from PT 5 TDM, plug into PT 5 LE and continue?
Yes.
-Mike Rockwell
Old 10-14-1999, 06:13 PM
Guest
Posts: n/a
HOLY s**t!
Is that cool or what!?
Thanks
Jules
Would I need to condence it down to have everything on one drive?
[This message has been edited by Julian Standen (edited 10-14-99).]
Old 10-14-1999, 07:48 PM
No.
-Mike Rockwell
P.S. I love these yes or no question ;-)
Old 10-15-1999, 02:30 AM
Guest
Posts: n/a
Wow!
cue more smiley faces
Thanks
Jules
Old 10-15-1999, 05:47 AM
mike_c mike_c is offline
What happens if you switch over to a system that doesn't have all the same plugs? Does it remember settings/info (just disabled), or is all plugin info lost?
Mike
hot swap drives on osx wallygrant Pro Tools TDM Systems (Mac) 3 05-12-2003 07:08 PM
Synchronization software for backing up to hot-swap removable firewire drives... scottlmicu Pro Tools TDM Systems (Mac) 5 04-05-2003 06:57 PM
Hot Swap Firewire Drives & PT RMD Pro Tools TDM Systems (Mac) 2 06-22-2002 01:32 PM
can I swap G4 internal drives? Rollerex General Discussion 16 01-26-2002 08:12 AM
Building Hot Swap Drives !! rat1016 General Discussion 5 12-06-2000 10:58 PM
