Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 09-22-2010, 04:40 PM
nickomatiz nickomatiz is offline
Default Mpowered 8.1, profire 2626, Clock issue
Hey all,
ive been searching for this issue for a while so i decided to post. I have M-powered protools 8.1 and was working perfectly. I rebooted my macbook from the factory disk, and installed protools again. I opened up a session and it sounded jittery and corrupted. I use a profire 2626, checked clock settings under the profire's application and clock source was the same as the session. I checked under protools and where you can select the session clock, it is greyed out and says 'see control panel'. Ive tried lots of stuff but nothing seemed to work.
Any one has had a similar problem? any suggestions?
thanks again
niko
Old 09-23-2010, 02:18 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: Mpowered 8.1, profire 2626, Clock issue
is the clock set to internal? Or do you have any digital connections? Is it also jittery on the headphone out?
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 09-23-2010, 02:20 AM
clausiii's Avatar
you have 8.1? If you mean 8.0.1, try an update to 8.0.4...
My ears! My ears!
clausiii
ProTools 2019.5
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Help With Set Up And Clock Issues 003 Rack+ Profire 2626 toolgirl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-27-2011 09:30 PM
Profire 2626 Issue gjohung Pro Tools M-Powered (Win) 15 05-31-2010 08:40 AM
Need Help plz, PT Mpowered and Profire 2626 System compatibility WolfKarpenter Pro Tools M-Powered (Win) 1 11-17-2009 03:11 PM
Unable to clock from Profire 2626 kevinb511 Pro Tools M-Powered (Win) 4 09-05-2009 09:03 AM
